Fosi Audio A5 Soundbar, 18 Inch Sound Bar with 4 EQ Modes & 3D Virtual Surround Sound Effect
Normaler Preis
$69.99 USD
Verkaufspreis
$69.99 USD
Normaler Preis
$69.99 USD
Color: A5-Black
Fosi Audio A5 TV Soundbar
Model A5
Output Power 60W
Channel 2.0
Input Mode HDMI(ARC)/OPTICAL/Bluetooth/3.5MM/USB
SNR >75dB
Bluetooth 5.0
Bluetooth Name Fosi Audio A5
Device Dimension 470 * 95 * 70MM
DC Input Range 15V
Power Supply 15V 3A
Fosi Audio A5 Soundbar x 1
3.5mm to RCA Cable x 1
Wall Mount Brackets x 2
Remote Control x 1
15V 3A Power Supply x 1
Video
Compare with similar items
Based on 4 reviews
75%
25%
John Opaczewski
Nice sundbar
William Vermeire
A5 Review
I had hoped that the sound bar I purchased would have a deeper richer sound quality. Since it doesn't it's unfortunate that there isn't any tone control built in. Also the volume control only adjusts for groupings of levels. For example Low, Medium or High. There is no control within the predetermined ranges. Overall, I was somewhat disappointed int the sound bar.
Tony Chen
A cost effective product comes with good accessories
I just received the product a few days ago and have experienced it for a while. The A5 soundbar quality is excellent as a stereo sound device, and it fits most genres like K-POP, bass, and classic.
The soundbar delivers accessories that cover the most frequently used items, such as the RCA and optical cable. I also like to use the remote control for the soundbar, and it is a comfortable way to turn it off or adjust it without pressing the buttons from close.
Chris Tugwell
No, the order wasn’t fulfilled. I was told the plugs were US fittings and not Australian, so I cancelled the order. If you can provide Australian 240 volt compliant plugs, I will happily renew the order.
