Luna3
Turntable
Built for Vinyl Lovers & HiFi Perfectionists Alike
Back Luna3 on Kickstarter
Fosi Audio Luna3 Turntable
Support Luna3 on Kickstarter
Less is More
Guided by the principle of “less is more,” Luna3 strips away distractions to deliver only what truly matters: a clean analog signal path, intuitive usability, and a timeless visual presence. Whether you’re a seasoned vinyl enthusiast looking for an upgradeable, customizable system, a HiFi newcomer ready for a serious first turntable, or someone seeking a meaningful, design-forward gift, Luna3 invites you into a slower, more intentional listening experience, one quiet revolution at a time.
Less. Better.
That’s the Luna3 Way
Minimalist Design
No built-in phono
Acrylic Platter
VM95E Cartridge
Lightweight&Rigid Tonearm
Less is More
Less. Better.
Nothing More Than a Turntable
Stripped of the Unnecessary to Preserve the Authentic Vinyl Sound
Fewer Circuits, Cleaner Signal
No built-in phono stage, no unnecessary paths. Just a clean, direct analog signal and full freedom to build your ideal setup.
Minimalist Design
A Modern Classic that Looks Right in Every Room
Seamless, Unified Aesthetic
Crafted with a unified plinth and finished in matte black, the Luna3 feels as refined as it looks.
Solid Acrylic Platter & Orange Mat
The heavyweight transparent platter ensures stable rotation and precise sound. Paired with the orange mat, it’s the ideal stage for your colored vinyl.
Precision-Crafted Metal Details
CNC-machined headshell and speed switch ensure lasting quality, highlighted with Fosi’s signature orange for added texture and style.
Headshell
Speed Switch
The Perfect HiFi Gift
Timeless Black, Effortlessly Blends In
Luna3’s black design fits naturally in any space. More than a turntable; it’s an expression of your style.
HiFi Sound
Experience Vinyl the Way It Was Originally Cut
VM95E Cartridge Detail & Balance
Delivers clear vocals and crisp treble with minimal distortion.
Servo Motor Control for Precision Playback
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Servo motor and Hall sensor keep rotation ultra-steady at just ±0.11% deviation.
Lightweight, Rigid Tonearm for Accurate Tracking
Low-resonance tonearm ensures stable playback with precise anti-skating control.
Copper Core Motor, Quieter Playback
Minimizes mechanical resonance for a clearer, more transparent sound.
HiFi Sound
Your heading text goes here
Servo motor and Hall sensor ensure ultra-steady rotation with ±0.11% accuracy.
Upgrade Potential
Easy to Start, Built to Grow, Made for Serious Audiophiles
Effortless Stylus Upgrades
The VM95E stylus can be easily removed and replaced, making it simple to to suit your listening style.
Compatible Headshell Connection
Standard universal connector lets you swap the entire headshell for easy system upgrades.
listening style.
Fosi Audio i5 features
Smart Practicality
Smart Features That Just Make Sense
2-Speed Control
33 / 45 RPM – play all your vinyls
Trigger Out Support
Synchronized power-on/off with your downstream devices
Auto Stop Function
Stops when the record ends – easy and safe
2-Speed Control
33 / 45 RPM, play all your vinyls
Trigger Out Support
Auto Stop Function
Speed
33, 45 (electronic speed change)
Speed Variation
33: 0.1%
45: 0.1%
Wow&Flutter
33: 0.1%
45: 0.15%
Platter
300mm (acrylic)
65dB
Tonearm Length&Matreial
 8.6in (aluminum)
Tonearm Diameter
12.2mm
Effective Arm Length
218.5mm
Overhang
22mm
Dimensions
420×112×330mm (W×H×D)
Weight
3.5kg
Power Consumption
5W (Max)
12VDC/1500mA
What's in the Box
Acrylic Platter*1
Headshell with Stylus*1
Platter Mat*1
Dust Cover*1
Counterweight*1
Plinth*1
45 Adapter*1
Rubber Belt*1
User Manual*1
12V Power Adapter*1
What's in Box
