Box X1 Phono Preamp for Turntable Pre Amp Amplifier MM Phonograph Preamplifier for Record Player with Volume Control Mini Stereo Audio Hi-Fi Pre-Amplifier with DC 12V Power Adapter Fosi Audio
Regular price $59.99 Sale
  • BOX X1 phono stage preamp converts phono signals to Line Level Signals with Low-noise integrated circuits and high quality components to remove low frequency noise ensure clear sound quality;
  • Small simple compact design with Gold-plated RCA input and output, can connect any vinyl records to home stereo theater amplifiers, receiver or powered speakers;
  • Easy quick setup for all MM (moving magnet) cartridges, Metal Aluminum case protects unit from vibrations and electromagnetic interference;
  • Necessary for connecting turntable to the speakers and receivers / amplifiers / powered speakers that do not have a phono input;
  • Small size allows installation close to record player, Come with 12V power supply and 18-month warranty, please contact us if you have any problems.
Parameter:
·  Converts Phono Signals to Line Level Signals
·  12-Volt DC 110V-240V Adaptor Included
·  Dedicated RCA Connectors
·  Output Level: 600Mv @3mV 1kHz
·  Load Impedance: 10K Ohms
·  S/N Ratio (with A-WTD): 98 dB
·  T.H.D. : 0.08 for 1 KHz 3 mV Input
·  Frequency Response:20 Hz ~ 20 KHz ±2dB
·  Input Sensitivity / Impedance / Phono - 3 mV / 50K Ohms
·  Dimensions (W x H x D):4.72'' x 3.93'' x 1.37''
·  Weight : 0.9 Lbs
