Alt image Alt image Alt image
Fosi Audio C3
AI-Powered Gaming Sound Card & DAC/Amp
AI-Enhanced Footsteps | Hear What Matters
Thank you for subscribing.
Check on Kickstarter
Buy on Fosiaudio
Buy on Aliexpress
Buy on Amazon
Buy on eBay
C3 Kickstarter Early Access
Make a $9.90 deposit to unlock exclusive campaign rewards, including a 25% discount and a special physical gift for early supporters.
Follow on Kickstarter
Make Your Deposit
C3 features a built-in deep learning–based audio enhancement system designed to address the issue of footsteps being easily masked by gunfire and ambient sounds in games, enabling automatic detection and enhancement of footstep audio. Unlike traditional sound cards which only adjust EQ, C3 boosts what matters, preserving ambient sounds and gunfire for accurate awareness even in chaotic battles.
Alt image Alt image
Hear the Difference. React Faster.
Hi-Fi Sound, Beyond Gameplay
With audiophile-grade components, C3 reveals subtle details in game audio, adding depth and realism without altering the original sound design.
Fosi Audio C3
Secure Your C3 Kickstarter Rewards:
 1. $9.90 deposit to reserve benefits
2. 25% Secret Reward access
3. Bonus physical gift after campaign
Make Your Deposit
Why C3 Isn't Just Another Gaming Sound Card?
Fosi Audio C3
Traditional Gaming Sound Card
Footsteps Lost in the Chaos?
A FPS-trained AI That Knows What to Listen For
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Surround Feel Missing?
Hardware-Level 7.1
That Rebuilds the Space
Spatial processing rebuilds direction and distance cues for a wider, deeper scene, providing more presence in 3A games and films.
Your Team Can’t Hear You Right?
AI Noise Reduction with Ultra-Low Latency
Filters out background noise like keyboard clicks, keeping your voice clean and clear with <50ms real-time processing.
Practical Controls for Clear Communication
Preset & Custom Audio Profiles Supported
Web-Based Control Panel
Switch between presets or fine-tune your sound with PEQ controls, all through a clean, browser-based interface, no software required.
Check the details
Designed for the Desktop
Rich Connectivity, Thoughtful Controls
Built for Gaming Headsets and Desktop Speakers
General Specs
Chipset
XMOS XU316 + CS43131 + TPA6120*2
Maximum Sampling Rate
UAC 2.0:PCM 32-bit/384kHz; DSD256
UAC 1.0:PCM 16-bit/48kHz
OPT:PCM 24-bit/192kHz
COAX:PCM 24-bit/192kHz
Supported Headphone Impedence
16-300Ω
Coaxial, Optical, USB-C (Power & Data), 3.5mm Microphone
3.5mm Headphone, RCA
Firmware Update
USB-C Online Update
Input Voltage
DC 5V
PEQ Page Link
https://cc.fosiaudio.com
USB Driver
Required for DSD/Foobar2000
Windows 7/8/8.1/10/11 (Driver Required)
Mac OS X 10.6+, Linux (Driverless)
Audio Parameters
3.5mm Headphone Output (UAC)
Rated Power Output
L+R ≥ 320mW+320mW (32Ω / THD+N < 1%)
123dB (A-weighting)
0.0004% (A-weighting)
Dynamic Range
123dB
Noise Floor
≤3μv (A-weighting)
Frequency Response
20Hz-20kHz (±0.06dB)
RCA Output (UAC)
Rated Power Output
≥2Vrms
124dB (A-weighting)
0.0005% (A-weighting)
Dynamic Range
124dB
Noise Floor
≤3μv (A-weighting)
Frequency Response
What’s in the Box?
What’s in the Box?
Hardware-Level 7.1
Spatial processing rebuilds direction and distance cues for a wider, deeper scene, providing more presence in games and films.
Check the details
