The Bluetooth Stereo Amplifier adopts a performance TPA3116D2 amp chip, dual-channel max output power 50W x2@4ohm +100W to get clear audio sound, no pop, no audible noise, dead silent when nothing is playing through it;
- U-disk input for convenient and portable use. Audio Input: U-disk/ Bluetooth/ RCA. Audio Output: Passive Speakers + Passive/Active Subwoofer.Support Music Format: MP3, WMA, APE, FLAC, WAV;
Speakers full frequency output, By using the custom treble bass knob and adjustable 40-300Hz cutoff frequency for the subwoofer, you'll be able to get the best sound;
Supports wireless playback from Bluetooth devices, Bluetooth 5.0 wireless music streaming technology with external antenna make a transmission distance of more than 15m/49ft; Remote control switches songs and adjusts volume within 16ft (5meters);
Full metallic shell to ensure high quality and durable, advanced circuitry design, built-in speakers protection circuit to ensure Hi-Fi clear and clean sound; With unrivaled sound for the customers who pursue HiFi sound;
Upgraded DC power outlet for safe use without sparks, included high quality 24V/4.5A power supply enough to drive most passive speakers and powered/passive subwoofer.
Specifications | Details |
Model | BT30E |
Chip Set | TDA7498E |
Output Power | 50W*2@4ohm+100W |
Terminating Impedance | 2-8Ω |
Input Mode | U-disk/Bluetooth/RCA |
Output Mode | Passive Speakers + Passive/Active Subwoofer |
Frequency Range | 20Hz-20kHz(±3dB) |
Bass Cutoff Frequency Range Adjustment | 40-300Hz |
THD | 0.05%@output 1W |
SNR | ≥98dB |
Bluetooth Transmission Distance | Up to 15m/49ft |
Device Dimension | L118 x W95 x H35 mm/4.6 x 3.7 x 1.4inch |
DC Input Range | 12-24V |
Power Supply | 24V 4.5A |
Item | Quantity |
Fosi Audio BT30E Amplifier | x 1 |
Remote Control | x 1 |
24V 4.5A Power Supply | x 1 |
CR2025 Button Cell | x 1 |
User’s Manual | x 1 |
