  • Output: RCA, Sub Out
  • THD: <0.00012%
  • SNR: ≥121dB
  • Powe Supply: 5V 2A
  • Fosi Audio DAC-Q6 *1
  • USER MANUAL *1
Customers praised this desktop DAC for delivering clean, detailed sound with excellent value. Many noted significant improvements in soundstage and clarity, calling it "best in price range." Some reported occasional echo issues in the right channel and clicking sounds when changing tracks via USB. A few wished for separate power/data USB ports and additional inputs. Overall, shoppers found it performs well above its price point.
  • 5 stars: 53 (82%)
  • 4 stars: 10 (15%)
  • 3 stars: 2 (3%)
Anonymous (Saudi Arabia)
Fosi Q6 – Amazing Audio Performance! 🔥
The performance is really impressive! You can clearly hear the difference in audio quality. The sound is clean, detailed, and much more enjoyable to listen to.
Overall, the Fosi Q6 is an excellent DAC with amazing performance for the price. Highly recommended! 👌🔥
Noted improvements over previous DAC
Began building an office listening environment about one year ago with an inexpensive Bluetooth receiver to stream music from iPhone through to a small tube preamp into a Fosi V1.0B amplifier and output to small efficient bookshelf speakers. This sounded adequate but knew It could be better with some modest additions.
Contacted Fosi for product information and support and a knowledgeable team member suggested I consider the Q6 Desktop DAC after understanding my setup up and plans. Purchased the Q6 and awaited delivery.
Once in hand I connected the iPhone directly into the Q6 input and the output to the tube preamp then to the Fosi amp. Much improvement in performance and sound stage with the small speakers! Then replace the small speakers in the audition with super efficient Klipschorns. Wow!! The sound was demonstrably better and after rolling the tubes to better performers in the preamp I am completely happy. Virtually all my old musical selections became NEW musical selections!!
I am very happy with this performance and would recommend the Q6 as a small system DAC and perhaps even a larger system component!
Don’t know what else I could do or add to improve the performance except for a better tube preamp or balance signal paths.
Nick (United Kingdom)
Yankele (Ecuador)
Perfect companion for my V3
Peter (Hungary)
0
07VFDInLCD (United States)
Michal (Czechia)
Jeff (United States)
Solid DAC
Richard (South Africa)
Awesome little DAC
Got the Q6 to feed into my GR70 tube amp. Been using this combo with my HD600 headphones. I can’t imagine anything sounding better than this setup honestly.
Recently received the Q6 DAC and GR70 tube amp to power my Sennheiser HD600 headphones. Honestly I can’t imagine anything sounding better than this. Music is exciting all over again. Both the Q6 and GR70 are great little devices, nice build quality and excellent audio.
Genaro
James (United States)
Basic and nice
Kennith
Frederick (Philippines)
Finally!
Madeleine
surely
The speaker will be upgraded.
very good 👍
Brad (United States)
Short Lived Excitement!
Well, the first day was impressive. No discernable distortion at high end; a tiny bit at low end. Dead silent when it's supposed to be. Great performance for
Hans (Norway)
It does what it is supposed to do
I connected the Q6 with optical in from my LG C2 55" Oled. And sometimes, several times each day, it gives an echo in the right channel. Last only a couple of seconds. Not a big problem, but annoying.
It will be interesting to see if the same happens when connected with the new Apple TV 4K when that arrives.
Sang (United States)
Fosi Audio Q6 Desktop DAC
j
john (United States)
Fosi Audio Q6 DAC is Great
Unit works very well. Simple controls that just function. Multiple connections. Sound is very good. I would say maybe best in price range. Fosi Audio service has been good as well. Thank you.
Sathya (India)
Great product
Its very good
Alan (United States)
Best economy DAC on the market
Using my new Fosi Q6 DAC is ideal. I've connected it to my WiiM Mini streamer, via optical, and kept my hi-res stream intact, and connected that into my Fosi BT-20APro amp. Now I can stream 192khz audio seamlessly at ease, and my system sounds better than ever. I have volume/tone controls at my BT20A, and I've got voice commands and parametric EQ (31 band!) in my streamer, and I couldn't be happier.
d
doug (United States)
Single USB Port
Would it be to much of an ask to have seperate power and data USB port's?
Steven (Canada)
Dylan (United States)
Great presence
