Fosi Audio DAC Q7 Bluetooth 5.0 Decoder QCC3003 Low Latency PCM2706 USB Optical Hi-Fi Amp , Digital-to-Analog Converter
Fosi Audio DAC Q7 Bluetooth 5.0 Decoder QCC3003 Low Latency PCM2706 USB Optical Hi-Fi Amp DAC
Normaler Preis
$74.99 USD
Verkaufspreis
$74.99 USD
Normaler Preis
$74.99 USD
Parameter:
Quick tips:
1. Q: All the cables are connected, but no sound output?
A: Check the indicator is on, turn on the power if the light is still off, at this point you can find the same output voltage power supply (must 12V) to check if the machine or power supply failure.
If the indicator light is on, check whether the select knob is in the right position.
If both of the above are normal, check the input device if it is paused.
2. Q: Why do loudspeakers make a lot of electric noise?
A: If you are not using the original factory standard power supply, please replace the power supply before testing. Many power supplies in the market have large interference coefficients, which will cause a lot of current sounds.
3. Q: Why the speaker has a drone when I just plug in the input cable but don’t connect the sound sources?
A: If you use unshielded signal lines, there will be interference signals entering the power amplifier. If you hate the sound, you are advised to use the shielded signal lines or unplug the signal lines.
4. Q: Why there is no sound when PC-USB connects to PC?
A: First press the PC-USB operation to confirm whether the digital playback output has been selected. If still no sound, you can restart the computer and repeat the operation again.
5. Q: USB Device not recognized on Windows?
A: Select Start, then type device manager in the Search box, and then select Device Manager;
Expand Universal Serial Bus controllers. Press and hold (or right-click) a device and select Uninstall. Repeat for each device;
Once complete, restart your computer. Your USB controllers will automatically install.
Packing list:
Compare with similar items:
Q4 Mini Bass Stereo Gaming DAC
Q5 Mini Headphone Amplifier
Q6 USB HiFi DAC Headphone Amplifier
