[Old Version] TB10A 2Ch Stereo Audio Amplifier Mini Hi-Fi Class D Integrated Amp 100W x 2 With Bass and Treble Control
Fosi Audio TB10A 2Ch Stereo Audio Amplifier Mini Hi-Fi Class D Integrated Amp 100W x 2 (Refurbished Unit)
Normaler Preis
$41.99 USD
Verkaufspreis
$41.99 USD
Normaler Preis
$69.99 USD
New Version TB10A mini amplifier:
2. Adop QCC3003 Bluetooth 5.0 chip that improved the sound quality;
Quick tips:
Some customers may see some slight sparks flying when they plug the power supply into the amplifier, because they use it in the wrong way, you need to connect the amp to the power supply first, then plug the power supply into the 110v AC outlet, don't worry about the sparks, because this is class d amplifier, the capacitors need to charge when the power in, it's normal and safe.
2. The amp will off when you switch off, but it’s normal that the power LED light stay on even switch off, the power LED to light on means the power supply in.
3. What will cause noise?
Poor quality audio cables, Sound source, Speakers, Other interfering signals; Incompletely connections.
Unplug the RCA cable, connect this amp to speakers, and then plug into the power supply, power on and volume on, hear whether the noise exists on speakers, if noise existed, the noise may from speakers or amp, so you need to change speakers for further confirmation. If no noise the noise may from the audio source.
Parameter:
User Manual
