TP-01 Subwoofer Amplifier Receiver 100Watt Mini Hi-Fi Digital Class D Integrated Stereo Audio Amp for Sub Bass + Power Supply
Normaler Preis
$59.99 USD
Verkaufspreis
$59.99 USD
Normaler Preis
$59.99 USD
Quick tips:
Model TP-01
Output Power 100W for Subwoofer
Terminating Impedance 2Ω-8Ω
Input Mode 3.5mm Audio Input
Output Mode Active Subwoofer + Passive Subwoofer
Frequency Range 20Hz - 120Hz (±1 dB)
THD ≤ 0.04%
SNR ≥ 98dB
Input Sensitivity ≤ 280mV
DC Input Range 12-24V
Power Supply 19V 4.74A
Fosi Audio TP-01 Amplifier x 1
AC Power Cord x 1
19V 4.74A Power Adapter x 1
Compare with similar items:
TP-02 Subwoofer Amplifier 220W
TP-03 Subwoofer Amplifier
