1.5m Dual 3.5mm to 4.4mm Upgraded Audiophile Headphone Cable.
Crafted with 48-strand super copper wire, featuring a twisted-braid design combined with an upgraded anti-vibration weave, and gold-plated pure copper connectors, this cable ensures high-fidelity audio transmission and exceptional durability.
Based on 2 reviews
100%
Ruud
Must have cable for the I5
I received my Fosi I5 with the standard cables and the upgraded cable.
I looked at and felt the standard cables and then the upgraded cable. To be honest, I haven't even tried the standard ones. They are really stiff and... uncomfortable.
The upgraded cable looks and feels much nicer. Best thing about it is it's flexibility.
You can fold the cable however you like or tuck it in your trouser pocket for example. Can't really do that with the standard cables.
Overall, a very high quality cable which is great to use. Expensive but worth it.
Keith Robertson
Cable upgrading
The upgraded care cable has more give and manoeuvrability much more improved than the basic cable
