Fan Fest 2026 | 25% Off w/ code FFS25
| Power supply range | 12v-24v |
| THD | ≤ 0.5% |
| SNR | ≥ 98dB |
| Input sensitivity | ≤ 280mV |
| Bluetooth transmission distance | 28ft |
| Terminating impedance | 2Ohm - 8Ohm |
| Output power | 100W + 100W |
| Input mode | Bluetooth and Analog |
| Bluetooth Name | Fosi Audio |
| Bluetooth chip | ATS2853 |
| Power supply | 24V 4.5A |
| Amplifier | 1 |
| Power supply | 1 |
| AC power cord | 1 |
| User’s Manual | 1 |
