Fosi Audio DA2120C 2.1 Ch Integrated Amplifier
2.1 CH Wireless DAC Hifi Amplifier with EQ Control. MAX Power Output up to 120Watts x2@4ohm. DA2120C can drive most home bookshelf/desktop/outdoor(passive) speakers and powered subwoofers, offering low distortion and acoustically accurate audio reproduction. The bright digital LED display lets you see the settings you change easily and remote control for hassle-free adjust the inputs mode/volume/bass/treble.
DA2120C high-performance integrated stereo digital amplifier adopts Texas Instruments TAS5352A chip, designed to drive a 4-Ω bridge-tied load (BTL) at up to 120 W per channel with low harmonic distortion, low integrated noise, and low idle current. The TAS5352A has a complete protection system integrated into the chip, safeguarding the device against a wide range of fault conditions that could damage the system.
2-in-1 High-Performance DAC Power Amplifier with Multiple Input Modes. DA2120C installed in a quality aluminum enclosure supports Bluetooth/RCA/PC-USB/Coaxial/Optical Input, easy installation to build a stereo sound system.
DA2120C Bluetooth 5.0 amplifier delivers sound in sync, so you can enjoy the freedom of wireless and high-fidelity streaming music. It reduces delay and improves the end-to-end speed of the audio transmission, resulting in high-quality, synchronized sound, so you never miss a beat. With a 6dBi high gain antenna for long-range streaming up to 65 ft(20m).
What You Get: DA2120C stereo amplifier x1, Bluetooth antenna x1, 32V/5A power supply x1, remote control x1, PC-USB Cable x1, Optical Cable x1, user manual x1, our worry-free 24-month warranty, and friendly customer service.
Specifications | Details |
Model | DA2120C |
Output Power | 2 × 125W at 10% THD+N Into 4 Ω 2 × 100W at 10% THD+N Into 6 Ω 2 × 80W at 10% THD+N Into 8 Ω |
Frequency Range | 20Hz - 20kHz (±1 dB) |
Bass frequency | 20Hz-200Hz |
THD | ≤ 0.01% |
SNR | ≥ 105dB |
USB Chip | Cmedia CM6642 SUPPORT 24bit/192Khz |
Amplifier Chip | American TI TAS5352A |
Bluetooth Chip | Qualcomm QCC3031 Bluetooth 5.0 chip supports aptX, aptX-HD, SBC, AAC |
DAC Chip | American Cirrus CS8422 chip USB, coaxial optical fiber Supported sampling rate 24bit/192Khz |
Device Dimension | L180*W130*H38mm (7*5*1.5in) |
System Supported | XP/W7/W8/W10/MAC/Linux |
Power Supply | 32V 5A |
Item | Quantity |
DA2120C Amplifier | x 1 |
32V 5A Power Supply | x 1 |
Remote Control | x 1 |
USB Cable | x 1 |
Optical Cable | x 1 |
AC Cord | x 1 |
User’s Manual | x 1 |
