  • The Fosi Audio BOX X3 is a state-of-the-art phono preamp that uses Bluetooth 5.0 5725W tube technology for superior audio quality. This 2-in-1 preamp serves as both an MM turntable preamplifier and a Bluetooth 5.0 preamp, making it an essential component for the modern audiophile
  • The tube phono preamp improves the audio quality of your MM turntable by converting the phono signal to a more manageable line level, resulting in better sound and increased volume levels for your home audio system
  • Upgrade your home audio setup with the BOX X3 Bluetooth 5.0 tube preamplifier. With a 3.5mm line input, easily connect your latest devices for wireless Hi-Fi music streaming to powered speakers. Please note that an amplifier is required for passive speakers
  • Experience exceptional sound quality with the BOX X3 phono preamp's ultra-low noise performance. Featuring 5725W vacuum tubes, this preamp produces a clean and warmer sound, allowing for perfect replication of your vinyl records' music. The built-in phono preamp circuitry is designed with high accuracy and conforms precisely to the RIAA standard, so you can enjoy a flawless listening experience every time
  • What You Get: BOX X3 mm phono preamp x1, 5725W Vacuum tubes x2, Bluetooth Antenna x1, power adaptor x1, user manual x1. Please note that the BOX X3 preamplifier is a Bluetooth receiver only
Model BOX X3
Output Interface RCA output
THD ≤ 0.1%
SNR ≥ 98dB
Product Weight 0.71 lb/320g
DC Input Range 12V
Power Supply 12V 1.5A
Box X3 Phono Preamp x 1
5725 Vacuum Tubes x 2
12V 1.5A Power Adapter x 1
Customers praised this phono preamp for its "clean and neutral sound" and excellent value. Most found it "works flawlessly" with simple tone adjustments and dual Bluetooth/phono functionality. One customer noted a minor LED solder issue but confirmed "the X3 plays great." Some needed setup optimization.
  • 5 stars: 13 (76%)
  • 4 stars: 2 (12%)
  • 3 stars: 2 (12%)
Gary (United States)
Price, function, and sound satisfaction
I find the sound of the preamp through the phono input/output to be very neutral and clean. I really like the simplicity of the tone adjustments and being able to isolate them to each source, especially phono.
I didn't have a bluetooth option prior to integrating this component into my system, so the dual functionality of bluetooth/phono was very welcome. The bluetooth side of the box X3 has the same pleasant neautral sound profile. Functionality is rudimentary, and no frills. I prefer warmer sounds, and it's so easy to dial that in or out with the X3.
Since incorporating the Box X3, I have also picked up a wiim ultra. The wiim also has both phono and bluetooth functionality. Attempting to reproduce the clean and neutral sound of the Box X3 with the phono and bluetooth inputs of the wiim can be obtained by extensive EQ and settings adjustments. However, the effort required to get the wiim to do what the Box X3 does naturally are why the X3 stays part of my setup.
The Box X3 is another clean, simple, low cost solution in the FOSI lineup.
Drx (Serbia)
Almost satisfied
Anonymous (Spain)
Perfecte!
Tomboat (United States)
Great Little Pre-amp
I've owned the Box X3 for a few years. It has never disappointed me. I have rolled different paired tubes to fine-tune it to my liking. I like it more than more expensive fancy pre-amps.
z
zoxy1955@gmail.com (Serbia)
Fosi Audio Box X3
Great preamplifier, I sincerely recommend it to everyone...
z
Fosi Audio Box X3
Joshua (United States)
Box x 3
Love it works flawless
Box x 3
Yuwei (Canada)
Good enough for this price
Yuwei (Canada)
Pedro (Portugal)
Pedro
Kevin (Hungary)
Great device, amazing support
Great product!
My only issue was solved by the amazing support staff, works like a charm and sounds great!
Kevin
Great product!
Robin
I like it but I'm going to have to play with it to find the optimum set up through my amp
