Products Fosi Audio BOX X1-MM Phono Preamp MM Turntable Preamplifier
Fosi Audio BOX X1-MM Phono Preamp MM Turntable Preamplifer With 3.5mm AUX Headphone Output
Fosi Audio BOX X1-MM Phono Preamp MM Turntable Preamplifier With 3.5mm AUX Headphone Output
Prix habituel
$39.99 USD
Prix soldé
$39.99 USD
Prix habituel
$39.99 USD
Phono Preamp for Turntable with Volume Control Box X1
Model BOX X1
Output Mode 3.5MM headphone output + RCA output
Input Mode MM turntable input, Grounding post input, 12V DC input
Output Active(powered) speakers, Headphone, Amplifier
THD ≤0.08% @ 1kHz and 3mV
SNR 70dB
Product Weight 0.35lb/161g
Device Dimension 3.94×0.98×2.17 inch
DC Input Range 12V
Output Voltage Level 2V max (P-P) at 10K Ohms
Power Supply 12V 1.5A
What's in the box?
Box X1 Phono Preamp x 1
12V 1.5A Power Adapter x 1
Compare with similar items:
Based on 3 reviews
100%
Sami Syed
Great service, products work as expected
I really appreciated the time their customer service took to help me get set up! I thought I had the wrong parts, but they helped me figure out how to get it working without having to buy yet another amplifier. Very quick and thorough.
Would recommend
Wanner John
Works as advertised
I'm not an audiophile so I don't have anything really to compare it to, but it works as a pre-amp from my low-end technics turntable to my Fosi BT30 amplifier and sounds good. The grounding post is handy since the BT amps don't have a ground the way traditional receivers do.
Daniel Lundberg
It worked
The phono inputs on my receiver were mediocre at best. Disappointing on an otherwise great receiver. Added a very basic phono preamp, now it sounds spectacular. $34 how about that for an excellent value!
