- High-Performance Amplifier
- 2.1 Channel Amplifier: The BT30D PRO integrated amplifier features two sets of passive speaker outputs and one set of passive subwoofer outputs, making it easy to set up a 2.1 home theater or other stereo HiFi audio systems.
- Exquisite Craftsmanship: This mini amplifier is meticulously crafted with a solid, all - metal body that ensures durability and longevity. The well-designed case, along with the high-quality controls and connectors, exudes a sense of premium build and attention to detail. The exquisite packaging further adds to the overall appeal and value of the bass amp.
- THD: ≤ 0.03%
- SNR: ≥ 108dB
- Input: Bluetooth + RCA
- Input Sensitivity: ≤ 600mV
