Effortlessly Switch Between Two Sets of Amplifiers/Speakers
The LC30 was specially developed to cater to our audiophile fans‘ requests to complement your home audio system setup. It can serve as an amp/speaker selector or a pure VU meter allowing you to enjoy the vibrant audio-visual feast.
  • Supported Amplifier Types: BTL, Class A, Class B, Class AB, Class D and tube amplifiers, etc.
  • Maximum Power Support: 250W@4Ω per channel
  • VU Meter Brightness Adjustment: 5 levels(100%, 75%, 50%, 25%, Off)
  • Power Supply Voltage: DC 5V USB-C
High-quality Relays
Leveraging superior internal components for high-power lossless output, creating an unparalleled exceptional listening experience for you.
390Ω Load Resistors
Designed to prevent amplifier no-load conditions, guaranteeing stable operation and extending lifespan.
Thickened Circuit Traces
Utilizes thickened copper foils in the circuitry to minimize power loss during audio transmission.
User-friendly Terminal Design
Terminals oriented upwards/downwards simplify the cable connection process, ensuring easy and quick connections.
  • AccessoriesVintage Elegance: The LC30 boasts dual large VU meters, complete with adjustable brightness across five levels. It offers versatile connectivity with two inputs and two outputs, enabling four distinct configurations. Beyond its functional prowess as a switcher, it stands as exquisite decorative VU meters allowing you to enjoy the vibrant audio-visual feast.
  • Versatile Compatibility: Fully supports a wide range of amplifiers. The large enclosure design accommodates not only two Fosi Audio compact amplifiers on top but also seamlessly integrates with traditional Class A, Class B, Class AB, and tube amplifiers without issues to meet your diverse audio enjoyment needs.
  • Superior Components: Integrated with 390Ω protective load resistors, thickened copper foil circuits, premium speaker binding posts, and switching relays, the LC30 ensures virtually no impact or loss in sound quality and supports a maximum 250W power transmission per channel. This allows you to enjoy the purest high-fidelity sound.
  • Ease of Use: Offers both button and remote control operation, enabling one-tap switching between two amplifiers and two speakers. It streamlines the process of A/B comparison testing for two amplifiers or speakers, ensuring straightforward accessibility. Moreover, adjusting the backlight brightness and needle sensitivity is made effortlessly simple, enhancing the overall user experience.
  • Crafted for Audiophiles: The LC30 was specially developed to cater to our fans' requests. It embodies the Fosi Audio signature all-aluminum alloy construction for durability and reliability, complemented by a 24-month official warranty for peace of mind. This device is destined to be a lasting companion for your HiFi home audio system, ensuring enduring satisfaction.
  • Input: up to 2 sets of amplifiers
  • Output: up to 2 pairs of passive speakers
  • Supported Amplifier Types: BTL, Class A, Class AB, Class B, Class D digital amplifiers, tube amplifiers, etc.
  • Maximum Power Support: 250W @ 4Ω (per channel)
  • VU Meter Size: 85 × 45mm
  • VU Meter Brightness Adjustment: 5 levels (100%, 75%, 50%, 25%, Off)
  • No-Load Amplifier Protection: Built-in 390Ω resistor protection
  • Supply Voltage: DC-5V
  • Fosi Audio LC30 x 1
  • Remote x 1
  • USB-C Power Cable x 1
  • User Manual x 1
The LC30 is a well-built amplifier/speaker selector with striking VU meters praised for its "clean, well-engineered" design and "excellent build quality." Customers appreciate the remote control convenience and seamless switching capabilities. Some noted VU meters require high volume to respond adequately, and a few reported occasional switching issues or desired trigger input for automation.
  • 5 stars: 108 (81%)
  • 4 stars: 18 (13%)
  • 3 stars: 5 (4%)
  • 1 star: 3 (2%)
Looks good- Works good
Works perfectly for switching between my Fosi preamp amplifier combo for spinning vinyl and my AVR home theater.
Ryan (United States)
A Clean, Well‑Engineered Switcher With Great Meters and Zero Gimmicks
I’ve been using the Fosi Audio LC30 for a few weeks and it’s been excellent. The big VU meters look great, and the black meter faces give it a sharp, understated look. The overall size is perfect — it sits on top of my Schiit Kara without blocking the vents.
Functionally, it does exactly what it’s supposed to. The sensitivity knob is genuinely sensitive, the speaker taps are solid, high quality, and accept thick‑gauge wire (if needed), and switching between amps is fast (rather, immediate) and quiet. I’m running a Schiit Gjallarhorn and two Dynaco Mark IV monoblocks into the LC30, then out to Klipsch Cornwalls, plus a high‑level feed to my subwoofer plate amp. Everything works seamlessly.
The remote is simple but very useful — I almost never touch the buttons on the chassis. LC30 isn’t just a desktop toy; it fits perfectly into a full living‑room system.
One thing worth noting: the LC30 is basically internal relays and LEDs drawing very little power, so it doesn’t come with a bulky power brick. It ships with a USB‑A to USB‑C cable (around 5–6 feet), and you supply your own 5‑volt adapter — which most people already have lying around. The power input on the back of the LC30 is USB‑C.
Also, ignore any reviews claiming it’s unsafe for tube amps. That’s incorrect. The LC30 places a proper load on the unused amp immediately. I can switch between solid‑state and tubes with nothing more than a relay click. My tube amps are safe.
Brightness control on the meters is nice to have, though I mostly use either LED‑off or max brightness. Maybe if I had the yellow VU version it would appear brighter and I would shift down the brightness more; or, if it were on my desk just a couple of feet from my eyes, perhaps then. But in the living room, max brightness is not too bright, even when I turn off all overhead and other bright room lighting. Also, I couldn’t tell if there’s a protective film on the meters? I think not, but sometimes I am not sure and I don’t want to pick at them.
For the price, this is a no‑brainer. No RGB, no gimmicky mic input that I have seen on other models, no nonsense — just a clean, well‑built selector and visual monitor with great meters and proper engineering. If you run multiple amps or speakers, or you just want real VU meters in your chain, the LC30 is the one to get.
Jorge (Mexico)
Bonito y de utilidad !
Richard (United States)
Dead out of the box, won't come on at all,
Dead out of the box, won't come on at all, paperweight.
Z (Vietnam)
Fosi LC30
Very nice, attractive
Solid, stable, high quality
Éasy operation, smooth in performing
We love it so much and certainly will recommence it to my clients
Z (Vietnam)
Fosi LC30
��asy operation, smooth in performing
William (United States)
Very nice switch
I really like this switch. It allows me to run two pairs of speakers that I wanted to compare for quite some time but I wanted to do it safely and discreetly. This VU meter switch is very discreet. The remote control makes it very easy to use. I haven't tried the amp switching capabilities yet, as I don't have a need for that at the moment, but I'll probably try that in the future. I can highly recommend this device.
Very nice switch
GOPAKUMAR (India)
Awesome
Good
GOPAKUMAR (India)
Awesome
Good
Just pure joy from something so simple
Not sure what it is but seeing these little things move from side to side make all my music just sound better hahahaha
I have no idea how to explain it but it just brings me joy looking at these things over and over.
Maybe one day I will use it as a switching station but for now it’s all cosmetic and I LOVE IT!!!
Guillermo (United States)
Maybe one day I will use it as a switching station but for now it��s all cosmetic and I LOVE IT!!!
Juan (United States)
Love Fosi but one feature missing
I sold my 6k audio system and picked up a full Fosi system. I was expecting a major downgrade in quality but the ease of use would make up for it as my wife is now cognitively impaired. I wanted to make things easier for her and Fosi's equipment fit the bill. I was completely blown away when I first fired up this system. The sound quality was noticably better than my previous set up. I don't know how they did that, but it's absolutely amazing. My only knock on the VU meters is that it doesn't have 3.5mm trigger switches like the rest of their gear. If it had that, it would be a 5 star product.
Henry (United States)
Excellent Product
Love it, bought a second so I can monitor both amps left and right channels.
Excellent Product
GB (Hungary)
good accessory
It would be nice if the width was like two ZA3s. It would be a plus if the dimensions and colors were the same. It would be a more aesthetic and organized system.
GB (Hungary)
good accessory
Ralph (Canada)
On point
Love my VU meters
They are great!
Thanks Fosi!
