  • Upgraded Design: Add Bluetooth to a subwoofer amplifier. M01-BT support Bluetooth and RCA input can drive most home passive speakers, passive subwoofers, and powered subwoofers. (Note: M01-BT is not suitable for active speakers). Easy to build a simple sound system with M01-BT.
  • Mini compact Class D Audio Amplifier. M01-BT SUB amp adopts ST Microelectronics TDA7498E high-performance chip, MAX power output up to 300Watts.
  • Switch to PBTL(As a full frequency mono amp): You can use the banana plugs or bare wires to connect the passive subwoofer to the M01-BT, use the RCA cable to connect the powered subwoofer to the M01-BT.
  • Switch to SUB(As a subwoofer amp): You can use the banana plugs or bare wires to connect the passive subwoofer to the M01-BT, use the RCA cable to connect the powered subwoofer to the M01-BT.
  • What you Get: M01-BT amplifier x1, Bluetooth antenna x1, User Manual x1, 24V/4.5A Power Adapter x1, AC Cord x1, 18-month worry-free warranty, and friendly customer service.
Model M01-BT
MAX Power Output 300W
RMS Power Output RMS220W@4Ω, RMS 110W@8Ω
Terminating Impedance 2-8Ω
Input Mode Bluetooth + RCA
Output Mode Passive Speaker + Powered Subwoofer
Frequency Range 20Hz - 20kHz (±3 dB)
Bass Frequency Range 20-200Hz
THD ≤0.05%
SNR ≥ 102dB
Input Sensitivity ≤ 0.2mV
Chip Set TDA7498E
DC Input Range 24-32V
Power Supply 24V 4.5A
M01-BT Amplifier x 1
Bluetooth Antenna x 1
24V 5A Power Adapter x 1
Compare with similar items:
  • 5 stars: 3 (75%)
  • 4 stars: 1 (25%)
Rajesh (India)
awesome!!
Very good product and strong build quality ,good appearance.i don't expect this sound quality, its very smooth sound and adjustable punch for better sound for sub woofer. if u make home sub woofer shut down your doubts and buy it,i ready to purchase another same piece.
DEVIN (United States)
Sub Amp
This little thing rocks. I have it hooked up to a 12in kenwood SUB. And I have hooked it up to 2 kicker solo baric 12's running from the aux out of th MC-101. I would definitely recommend this to anyone looking to build a nice little sound system with some old car audio sub's they might have laying around.
P (India)
Good buy
Nice bass
Gershon (Israel)
The M01-BT is an excellent product, easy to use, and outstanding performance
