Operation Guide
  • 5 stars: 25 (93%)
  • 4 stars: 0 (0%)
  • 3 stars: 2 (7%)
Anonymous (United Kingdom)
MARCELO (Spain)
Good quality and stability. Perfect for the V3 Mono and others of similar size.
Yashiko (Canada)
Fosi Audio 3-Layer Acrylic Rack
Absolutely love it.
Yashiko (Canada)
Absolutely love it.
Roberto (Ireland)
Great size and fit with fans
works very well with the fans attached above the Fosi monos, very quiet operation and esthetically pleasing, compared to fans sitting on top or below the monos
Roberto (Ireland)
Nikolai (Norway)
Good quality
I got this off of a friend and I liked the quality alot
Nikolai (Norway)
Good quality
Cesar (Mexico)
Ajuste perfecto
El ajuste es Perfecto y se ve genial. Les muestro mi escritorio. Recomendado
Cesar (Mexico)
Ajuste perfecto
SORIN (Romania)
Excellent. Solid. Love it!
Ivan (Canada)
Ivans great buy!!
It so fittingly perfect one of the best deal of my life well spent money!!
Ivan (Canada)
Ivans great buy!!
f
fede (Italy)
ok
tutto ok
f
fede (Italy)
ok
tutto ok
Bioguy01 (United States)
Good idea poor execution
I really wanted to like this rack. My main issue is my ZP3 can only set on top. The ZP3 is too wide to fit between the support posts on the bottom or second level. This needs to be addressed by making the rack wider by 10mm (3/8") between the post locations.
A.B. (United Kingdom)
Space saving
Rack is sturdy and well made the cooling fans fit well and help cool my V3’s. I will not be worried about over heating them in the summer months. I may need to but another when I start adding to my collection of Fosi products.
Andrew (United Kingdom)
Space saving
Rack is sturdy and well made the cooling fans fit well and help cool my V3��s. I will not be worried about over heating them in the summer months. I may need to but another when I start adding to my collection of Fosi products.
Francesco (Italy)
Rack per mini Hi-Fi concreto e ben costruito ma costoso.
E' un'ottima soluzione, che nelle misure è pensata bene per contenere e mantenere in ordine la componentistica "Fosi Audio". Il prezzo è tuttavia eccessivo per quanto offerto: pur se gradevole esteticamente, si tratta pur sempre di un mobiletto largo solamente 28cm, alto 23 cm e profondo 18.
Graham (United Kingdom)
Audio rack
Beautifully engineered and finished, and needless to say, perfect for the job!
Audio rack
Soureysen (Mauritius)
Lovely little Rack for my Stack of Fosi Products
This is really a neat product, easy to assemble, fairly stable, the price looks about just right for me to have placed the order. It allows me to stack my ZD3, ZP3, 2x V3 Mono and LC30 in a much lower footprint
Leonidas (Greece)
Nice little rack for Fosi components. Easy to assemble, no tools needed.
Material seems to have no issue at all handling the heat of two V3 mono amps.
A bit marginal size, for the bigger components, like the ZP3 preamp, that was a tight fit.
I did end up buying two of these, so I can eventually fit all the components I plan to get.
Leonidas (Greece)
Stephen (United Kingdom)
Fantastic bit of kit
This hi-fi stand compliments all of the range of fosi audio components that they sell
