  • Excellent sound performance: Low ground noise, built-in output protect the circuit, no buzzing or ringing noise, Audiophile-level sound quality, exclusively designed for the customers who pursue HiFi sound; and safe for your expensive headphones.
  • Stereo and Preamplify: Headphones amp also can be used as a stereo preamp, Parallel 3.5mm and RCA stereo inputs, 6.35mm headphone output, include a 6.35mm to 3.5mm adapter;
  • High-performance: P2 is a Hi-Fi tube headphone amp, 2 X 5725 tubes can easily power high-performance headphones including the HD580, HD600, HD650, K701, K702, Q701, and many more, recommend 32-300ohm headphones
  • Easy replace tube: Tubes can be replaced by JAN 5654W/6j1/6J4/GE5654/6AK5/6*1n/ E180F/6ж9П/EF861/6688 tubes etc
  • Exquisite appearance: Small Compact Size, All aluminum alloy shell and come with an 18-month manufacturer's warranty.
Headphone Amplifier Vacuum Tube Headphone Amp Mini Hi-Fi Stereo Audio with Low Ground Noise Output Protection for Headphones Fosi Audio P2
Model P2
OP-Amp NE5532
Headphones Output 16-64Ohm
Headphone Impedance 32-600 Ω
Input Mode 3.5mm Audio jack, Stereo L / R RCA
Frequency Range 20Hz-20 kHz (± 3dB)
THD ≤0, 03%
SNR ≥ 95db
Input Sensitivity 0.2mV
Device Dimension L99 * W98 * H33 mm
Device Weight 0.25 kg
Operating Voltage DC12V
P2 Headphone Amplifier x 1
5725 Vacuum Tubes x 2
DC 12V Power Supply x 1
6.35mm to 3.5mm Adapter x 1
Compare with similar items:
P1 Pro Bluetooth 5.0 Tube Preamplifier
P1 Vacuum Tube Pre-Amplifier
  • 5 stars: 1 (25%)
  • 4 stars: 2 (50%)
  • 1 star: 1 (25%)
Ioannis (Norway)
Excellent device
I am amazed that it has zero noise combined with my scarlett focusrite 16i6 i carnked up the volume and it has literally zero hiss at max levels.
Jeff (United States)
Incorrect replacement tubes
Description says you can use E180F, EF861, and 6688 tubes. These tubes are 9 pin! They don’t fit in a 7 pin sockets on a P2! I had a premium pair of Mullard NOS E180F tubes I was going to use in this amp. One of the main reasons I purchased it! Very disappointed in your documentation. You must correct immediately.
TIBOR (Canada)
Good headphone amp with some base noise.
My Bayerdinamic 990-pro 250 ohm headphones can't drive properly.Very clear, nice sound, but the power of the amp is too low for these headphones.
TIBOR (Canada)
