  • Output: RCA, Sub Out
  • THD: <0.00012%
  • SNR: ≥121dB
  • PC-USB support operating system: XP/W7/W8/W10/MAC/linux
  • Powe Supply: 5V 2A
  • Fosi Audio DAC-Q6 *1
  • USER MANUAL *1
Based on 20 reviews
95%
(19)
5%
Kyle O'Neill
Fosi Audio Q6 Desktop DAC
Demetry
I recommend!
Clean and detailed sound. Very good as an upgrade to an old CD/DVD player.
Chetan Mutke
Audio quality improved, but ₹470 extra charge ruined it
I paired the Fosi Q6 with my Edifier speakers, and yes — the audio definitely improved. The sound is cleaner, more detailed, and louder than using onboard audio. If you're after a basic DAC/amp to upgrade your setup, this one does the job.
But honestly, I'm very disappointed that I was charged ₹470 extra with no reason or explanation. There was no tax or shipping breakdown — just an unexpected charge that left a bad impression.
Dick Howell
The product arrived, everything is fine! Haven't listened yet, the cable hasn't arrived yet, I'll add a review later!
Barton Ortiz
excellent DAC for this price. soft. Transparent and detailed sound. I liked it more than topping E50 and E30-2.
