Fosi Audio TP-02 TDA7498E Subwoofer Amplifier Receiver Mini Hi-Fi Class D Professional Integrated Amp for Sub Bass Shakers 220W
Prix habituel
$79.99 USD
Prix soldé
$79.99 USD
Prix habituel
$79.99 USD
Version:
Quick tips:
Model TP-02
Output Power 220W for Subwoofer
Terminating Impedance 2Ω-8Ω
Input Mode RCA
Output Mode Passive Subwoofer /
Powered Subwoofer
Frequency Range 20-200Hz
THD ≤ 0.04%
SNR ≥ 98dB
Input Sensitivity ≤ 280mV
Device Dimension 5.12 x 3.54 x 1.58 inches
DC Input Range 12-24V
Power Supply 24V 4.5A
Fosi Audio TP-02 Amplifier x 1
AC Power Cord x 1
24V 4.5A Power Adapter x 1
Download TP-02 User Manual
Compare with similar items:
Based on 4 reviews
100%
DM
Highly recomended.
Worth every penny. Paired with Fosi BT20A PRO and polk audio speakers. Sounds amazing.
Eric Hight
Packs a punch, don't even think twice about getting this!
I hooked this into a jbl 160 with a failed plate amp that houses an 8" 4ohm svc subwoofer. This little beast can easily overdrive that woofer at 60%. Played for about 10 minutes in the garage and the unit was cold to the touch. Next I'm going to try two 12" dvc subs at 2 ohm. I have no doubts that it will be up to the task. Very impressed. Crazy how far amp technology has come since I was a kid. Only test now will be longevity. I'll try to update if anything changes.
Dorian
Excelent
Very powerful for bass shaker Dayton Basx A300 . Good good product
Sam Gibb
Great amp for my Lii audio w21 woofer
This replaced a cumbersome plate amplifier and I lost nothing in performance
