Ensure your V3 MONO, V3 and BT20A PRO amplifier stays cool and performs at its best with our 125mm × 25mm Cooling Fan.
This fan has a convenient USB plug and is designed for easy setup and reliable cooling, keeping your components running smoothly.
Optimal Cooling: A large 125mm fan ensures efficient heat dissipation.
Plug-and-Play: USB-powered for easy and flexible installation.
Versatile Use: Ideal for cooling various amplifier components.
USB-powered cooling fans effectively reduce amplifier heat to room temperature. Customers said they are "super quiet" and "nearly silent" with adjustable speed control. Some noted fans lack an off switch and run continuously when plugged in. A few mentioned louder noise at max speed and desire for trigger activation.
  • 5 stars: 32 (78%)
  • 4 stars: 6 (15%)
  • 3 stars: 2 (5%)
  • 1 star: 1 (2%)
Russell (United States)
The fan are a must
The fans work great I would recommend adding them asap.
The fan are a must
John (Australia)
Cooling fans
Didn't experience overheating like some have mentioned, but bought fosi's cooling fans anyway. Now amps run at ambient room temp. A really worthwhile investment.
ESA
Tuote tuli ilmoitetussa ajassa, hyvin pakattu ja toimii.
MARCELO (Spain)
All good. They are silent and work perfectly well.
Anonymous (Italy)
Excellent product, a must-have for cooling a V3 stereo 48V
Ed (United States)
Super quiet
The fans work great. I got them to use on the (2) ZA3s that I
purchased on the same P.O.
I assumed the ZA3s had holes on the bottom of the chassis, as I was planning on placing a fan under each of the ZA3s. Since the amps only have holes on the sides, I now stack the amps on each other and place (1) fan on the side, blowing into both amps. This works great at keeping the amps cool, as these amps get very hot without the fan.
Ed (United States)
Super quiet
JazzPirate (United States)
Keeping it cool.
Fosi Audio cooling fan does a fine job keeping my amplifier cool. Super quiet and easy to set up.
Dave (United States)
Keeping it cool.
j
jason (United States)
could be improved
First of all, they work. Set them up with my V3 mono amps and they help keep them cool. However, I have them plugged into the usb port on my receiver and they run all the time. It would be nice if they had an off switch. If they had a way to be turned off without having to actually unplug it they would get 5 stars.
James (United States)
Cooling M70 Yamaha AMP
Quiet Fans Thought that they would of had more air flow than what I expected Vintage Amp like the M70 generates a lot of heat Just trying to keep it cooler
J.
Perfect to keep an AVR cool.
J.D.
Ralph
They are too big for my FOSI RACK
To fit with my two FOSI ZA3 amps
So I have to stack them on top each other at the side of the rack.
Ralph
Brian (United States)
Works fine, needs longer cord between fans, trigger
If you want to use this kit with the mono amps right next to your speakers, the cord between them isn’t that long.
Also, you have to basically leave the fans on all of the time or manually turn them off. Maybe add a trigger so that when an amp turns on the fans turn on.
Victoria (Ukraine)
Hi guys!
Really very, Very quiet cooling fan. USB switch working only one way , and very good , what can possibly change speed of stream !
Victoria (Ukraine)
Hi guys!
GSM (South Africa)
V3 Fans
Works very well. Very quite and speed control is a nice touch.
GSM (South Africa)
V3 Fans
Works great
Perfect size with good rubber feet. Very quiet. Much more quiet than a typical PC cooling fan.
Johannes (Italy)
effective but not inaudible
the amps stay cool but one of the cooling fan is clearly to loud...
Works great
Johannes
Darrell (Canada)
Fans are a Go!
Now, I have a total of three fans. Tow on a couple of V3 Monos and 1 for a BT20A Pro. They work well and are very quick; there is some noise as max speed, so I back off to about 3/4 speed, hence a 4/5 rating. Hey Fosi, may I suggest one designed for the ZA3.
Darrell (Canada)
Fans are a Go!
RS (United States)
Great accessory for the V3 Mono amps
Impressive cooling. They don't spin real fast and are nearly silent. They really work well. I have them under both my V3 Mono's.
RS (United States)
BobbyD (United States)
Have not received Product yet
So,,, until I receive it.....1 Star
