  • Advanced circuitry design, built-in speakers protection circuit, solid aluminum chassis for long time use, small size, good looks, simple functionality, and excellent sound quality;
  • Best for bookshelf/computer/desktop/speakers in your room, connect to your Phone/MP3 player/DC/TV/Echo Dot as input, 50W X 2(4 ohms, 20 Hz - 20 kHz, 0.04% THD) can drive 2Ohm - 8Ohm speakers;
  • Simple compact design but practical and powerful, Adopt TI TPA3116D2 chip to get clear and clarity sound, no audible noise, dead silent when nothing is playing through it;
  • Aluminum shell and Aluminum knob to sure high quality come to a 19V power supply that can fit with the amplifier well. 24-month warranty, you can return the item if you have any problems;
Fosi Audio V1.0G 2 Channel Stereo Audio Class D Amplifier Mini Hi-Fi Professional Digital Amp for Home Speakers 50W x 2
Model V1.0G
Chip Set TPA3116
Output Power 50W x2@4Ω
Terminating Impedance 2Ω-8Ω
Input Mode RCA
Output Mode Passive Speakers
THD ≤ 0.04%
SNR ≥ 98dB
Input Sensitivity ≤ 280mV
DC Input Range 12-24V
Power Supply 19V 4.74A
Fosi Audio V1.0G Amplifier x 1
19V 4.74A Power Adapter x 1
Video
Compare with similar items
  • 5 stars: 2 (33%)
  • 4 stars: 4 (67%)
Nikolai L.
Works well
I bought this amplifier at first but later got a new one to suit my needs, but this worked well for when I had it
Nikolai L.
Works well
Jacob
A fine product
The amplifier works as expected, with no audible noise apart from a slight crackling when adjusting the volume knob
Jacob
A fine product
Neoklis K.
Fosi Audio V1.0G
Package arrived int time and undamaged.
Amplifier looks well made in good enclosure and works well.
Only problem I have, as a Radio Amateur, call sign 5B4AZ, is powerful noise interference between 27 and 30 MHz that is apparently produced by the switching power supply. This problem existed with a similar amplifier of another make I had before the Fosi. Switching supplies and amplifiers don't agree with sensitive radio receivers but seem unavoidable. :-(
Neoklis K.
Fosi Audio V1.0G
