Halloween Sales | 40% Off w/ code EHD40
| Model | T10 |
| Output Power | 100W +100W@3Ω |
| Terminating Impedance | 2Ω-8Ω |
| Input Mode | Wi-Fi + Bluetooth + U-Disk + AUX |
| Output Mode | Passive Speakers + PRE-OUT |
| Frequency Range | 20Hz-20kHz(±1dB) |
| THD | ≤ 0.01% |
| SNR | ≥ 115dB |
| Bluetooth Transmission Distance | 32ft/10M |
| Bluetooth Name | Fosi Audio T10 |
| Wi-Fi Name | Fosi Audio T10 |
| Device Dimension | 148mm (length) x 115mm (width) x 29mm (height) |
| Power Supply | 24V 4.5A |
| Fosi Audio T10 | x 1 |
| Remote Control | x 1 |
| Antenna | x 2 |
| 24V Power Supply | x 1 |
| User’s Manual | x 1 |
Video
