  • Fosi Audio ZH3 x 1
  • 6.35mm Adapter x 1
  • 12V Trigger Cable x 1
  • IR Remote x 1
  • User Manual x 1
  • USB-A/C to USB-C Cable x 1
  • DC 12V Power Adapter x1
USB not recognized?
Based on 9 reviews
78%
(7)
11%
11%
Håkan Lekberg
Good but not as a preamp
Sound is great with AKM DAC chip.
I was planning to use it as a combined DAC/ preamp with the possibility to have bass and treble control. As you all know different recordings needs sometimes to be adjusted in bass and treble. Unfortunately you can not use bass and treble control when in rca out mode. I could send it back and get a refund. The Fosi support is very friendly.
Jose Labastida
Great headphone Amp!
Martin Bonadio
It’s a decent unit that performs as expected in my fosi stack. The DAC sounds about as well as the one on my WiiM and the filters don’t really change the music much. The headphone amp is better than average.
Mille
Great
Sounds so good
Filex
very good DAC/Amp
Justgot it !Very easy to use, and easy to operate.
Sounds great with my i5
