  • Fosi Audio BL20A is a powerful Bluetooth 5.0 HiFi stereo amplifier with AUX pre-output, which can be used as a pre-amplifier. Design Treble & Bass control and remote control to meet your more needs.
  • The BL20A power amplifier supports AUX/U-Disk/Bluetooth input, suitable for most home passive speakers. Using two low-distortion TPA3116 high-performance chips to display ultra-high-definition sound quality.
  • Let's join the audiophile’s music journey with Fosi Audio BL20A Amp!
Model BL20A
Chip Set TPA3116*2
Output Power 100W x 2
Terminating Impedance 2-8Ω
Input Mode Bluetooth, AUX, U-disk
Output Mode Speaker’s Output + 3.5MM AUX Pre-out
Frequency Range 15Hz-20kHz (±1 dB)
THD ≤0.001%
SNR ≥92dB
Input Sensitivity ≤500mV
Support Format MP3/WMA/APE/ FLAC/WAV
U-Disk Capacity MAX 32GB
Bluetooth Transmission Distance Up to 164ft/50m
Device Dimension 3.54×4.72×1.18 inches
Product Weight 0.71lb/323g
DC Input Range 12-24V
Power Supply 24V 4.5A
BL20A Bluetooth Amplifier x 1
Remote Control x 1
24V 4.5A Power Adapter x 1
AC Cord x 1
We will send the correct plug type according to destination Country
You can also check our BL20C 160W x2 Bluetooth 2.1 CH Amplifier.
Based on 13 reviews
85%
(11)
8%
8%
Jordi
Impresionant
Molt bon so per un equip tan petit i a un preu tan baix.Tinc uns altaveus antics pero molt bons i volia un amplificador amb bluetooth per seguir utilitsant los.El resultat es espectacular.
Anthony Wall
Impressed
Id recently changed speakers from a pair of Wharfedale Diamond 11.2 to A set of Wharfedale Diamond 12.2 plus centre speaker. The 11 series are good and my pair were immaculate and didn't want to get rid of them so put them In the bedroom. I didn't want a full size amp due to space so looked online at various mini amps, looked at numerous forums and Fosi always seemed to be mentioned. I must admit I was a bit dubious buying the amp due to it being chinese and was concerned about build quality. However I took the plunge and was somewhat surprised when it arrived. The first shock was the size, I mean it's tiny. Build quality is very good. Sound quality is very impressive for a piece of kit that's so small and sub £60. If you crank the volume right up it does tend to distort slightly in the low bass range but as this is a bedroom speaker set its mainly som chilled jazz or blues that's being listened to, not the thrash metal on the main set in the front room. The remote is a bit on the crap side, you have to be directly in front for it to work but what do you expect for so little cost. Overall however I can't really fault the whole package.
Edwin Woods
Spectacular
Work spectacular! Purchased this item to power up speakers in my wood shop. Wanted more sound than a portable blue tooth speaker. Set up was easy and simple. The remote makes it much easier to operate. The sound quality is also spectacular coming from an old pair of Polk Audio speakers. Very happy with my decision to purchase this product.
Raj Kishor
Amplifier is powerful
Amplifier has good potential and powerful but some cons are there such as on off switch and heat issue after some time of use otherwise amplifier is good enough for good bass
Mohamad Nabil Hijazi
Good Product
Good product for my application. I hope some time to upgrade the BL20A to have screen for track indication, and output LEDs and volume indication to 100% suit my application. I am Mohamad Nabil Hijazi, bought so far 10 units and using it for electromagnetic coils
