80W Toroidal Transformer
Nippon Chemi-Con Capacitors
High-Reliability Rectifier
4-Core Regulation
Power Three Devices Simultaneously
With dual DC outputs and one USB-A output, the PSU20 can power up to three audio devices from a single source.
Flexible Compatibility
Supports selectable 5V, 12V, and 15V outputs, making the PSU20 compatible with CD transports, DACs, headphone amplifiers, and preamps.
3 Fully Isolated Outputs
Each output has its own dedicated rectification, filtering, regulation, and protection circuitry to deliver clean, stable power without interference between connected devices.
0.1mV Ultra-Low Ripple
With ripple as low as 0.1mV, the PSU20 helps reduce ripple noise and deliver a cleaner background for high-fidelity audio systems.
Engineered for Stable Long-Term Use
A custom low-noise fan activates at 55°C and operates at just 30dB, while over-temperature, over-voltage, and over-current protection help safeguard connected audio equipment.
Power Input
AC: 115V / 230V
Note:
Power Output
Operating Temperature
-20 ~ 40°C (-4°F ~ 104°F)
Temperature Rise Test
  • Fosi Audio PSU20*1
  • User Manual*1
  • AC Power Cord*1
Customers praised this linear power supply as "heavy and robust" with excellent value. Most reported improved sound quality, lower noise floor, and expanded soundstage. The dual output design simplifies setups by powering multiple devices from one source. However, some experienced compatibility issues with certain equipment and one unit had a dysfunctional output.
  • 5 stars: 10 (77%)
  • 4 stars: 1 (8%)
  • 3 stars: 1 (8%)
  • 1 star: 1 (8%)
No more clutter and better sound!!! This is what
No more clutter and better sound!!! This is what makes this device so wonderful.
I know some people say this type or porter supplies as snake oil but to be honest I see a difference in sound , not crazy but there is a difference.
Then on top of that you stop have 3 cables and power adapters and just one unit for all. This is also a fantastic win for me, not just because it looks amazing but you can also fine many videos that measure the device and it ranked among the top.
Definitely recommend
Peter
You cannot go wrong with this power supply it is heavy and robust
Harmohit (United States)
Excellent!
Using it as a power supply for the $4K Silent Audio Bonn NX - and it’s doing a great job! It’s as good as the Farad linear psu at 1/5th the price for my application.
DAVID (Colombia)
Capable, practical and useful
I received this PSU a month ago. I wanted to compare it against a 50W DIY PSU that I have, which has the so-called R-core transformer. I noticed that although the DIY PSU is good, as witnessed when listening, the GR70 that I have picks up some noise when warming up. However, when connected to the PSU20, the noise picked up is very, very little, which is expected when reaching the tube's optimal operating point. Currently running at the same time with the ZD3, I raised a query to Fosi Audio Support concerning the fact that the rated power of the GR70 is greater than that advertised in the specifications. Fosi confirmed that it is safe. So far, the fan has not even turned on — I guess that's good design. The 5V input is very useful too; I'm using it with portable DACs.
GR70 → DC2 (12V/5V)
ZD3 → DC1 (12V/15V)
Richard
Excellent
Anonymous (Malaysia)
Fosi Audio PSU20 Linear Power Supply
I used it to power my Fosi ZH3 and S3. It helps simplify the connection to power, One plug less and so far seems pretty good.
DocHouse (Germany)
Block of energy
The powerhorse of Fosi near to corefusion
John (Malaysia)
Beverley (United States)
Multi inputs
Good variety of inputs and sound quality for the price.
Jerome (United States)
Great Product, Noticeable Difference in my System
I have this powering my LAIV Micro Dac, before and after comparison, i can say that now I can hear more instrument separation and definition and owing to a lower noise floor the soundstage got expanded noticeably. Thanks Fosi Audio for yet another great value product!
Rob (United States)
Works well for one piece of equipment- not at all well with another.
While the PSU20 seems fine with a iFi Audio Zen streamer (15v), it most certainly had a negative effect on the quality of sound in the Laiv Audio uDDC it powered (5v). The degradation of sound quality was noted by multiple people and was not subtle. With the Laiv uDDC, powered by the Fosi PSU20, the sound produced was flat, compressed, muddy, uninteresting and nearly unlistenable. Instruments and voices lacked proper timbre and simply didn’t sound right. It resulted in a poor listening experience. As always, your results may vary. I was excited to have one PSU to power both the streamer and the uDDC- but was disappointed.
Daniel (United States)
One clean power source for two devices
The PSU20 powers my ZD3 (12V) and my WiiM Pro streamer (5V) from one box — one clean source instead of two wall warts. Rock solid, less clutter behind the rack, no noise in the chain.
Keith (United States)
Half dysfunctional, half great
Purchased to power my GR70 and Box X2. One of the 12V outputs would blink and not power the connected device. Working through a return and exchange now.
