  • Versatile Connectivity: Supports both Bluetooth and 3.5mm wired input. Experience high-fidelity, low-latency music anytime and anywhere. Also functions as a desktop Bluetooth receiver and amplifier, making it an ideal partner for HiFi headphones.
  • User-Friendly Design: Designed with you in mind. Compact yet equipped with rich adjustment features and easy controls. Features a rotary volume wheel to prevent accidental operation and easy-to-use gain switch and bass boosting toggle.
  • High Performance: Incorporates the OPA1656 op-amp, perfectly supporting headphones up to 300 Ohms impedance, ensuring clear and clean sound. Crafted by audio professionals with two decades of expertise, you're guaranteed an immersive experience where no musical detail is left behind.
  • Long Battery Life: Powered by a robust 1200mAh lithium battery, the N3 promises up to 10 hours of uninterrupted audio bliss. The isolated power design further ensures consistent and pristine sound quality, letting your music play on without a hiccup.
  • Exquisite Craftsmanship: Beyond its stunning looks, the CNC-machined all-aluminum alloy body guarantees durability with a premium touch. Feel the difference in every interaction and rest easy knowing you're backed by Fosi Audio's 24-month warranty.
Fosi audio N3-2
Fosi audio N3-3
Fosi audio N3
Fosi audio N3-1
Fosi audio N3-4
Model N3
Input Bluetooth, AUX
Output 3.5mm Headphone Jack
Op-Amp OPA1656
Headphone Impedance 16-300Ω
RMS Power 138mW @32Ω 15mW @300Ω
SNR 95dB
Frequency Response 20Hz-20kHz
THD 0.001%
Bluetooth Codec SBC
Power Supply 5V/1A
Battery 1200mAh (Up to 10-hour playback time)
Weight 300g
Dimensions 90x50x12mm
Fosi Audio N3 Headphone Amp x 1, Type-A to Charging Cable x 1, User’s Manual x 1
N3 User Manual
Based on 4 reviews
25%
75%
Jason Bass
Fantastic!
The headphone cable adapter for my iPhone became too touchy, disconnecting and generating noise. I got the N3 to replace that. Then I realized my upgraded motherboard had Bluetooth, which I never used for audio before, and thus I am able to play music from my PC, over headphones, as I walk around the house. The audio quality is excellent. Battery life is at least 12 hours. Pairing works very well. From the PC the range is at least 150 ft. There are $15 and $20 counterparts for sale, but they're cheap plastic with very limited battery life. This device feels more solid than a typical cellphone, no heavier, fits in a small pocket and does an excellent job of everything I expected from it.
Suresh Bala
Fosi Audio N3 Portable Bluetooth Headphone Amplifier Receiver
Frank Ostrander
Finally, a Bluetooth receiver that doesn’t skimp on the bass!
I am generally very happy with this unit. It’s solidly and handsomely built, doesn’t make annoying loud beeps, and has full-sounding low frequencies (I have a number of Bluetooth receivers that can’t drive low-impedance devices such as headphones or ear buds without skimping heavily on the bass). I really like having a rotary (analog) volume control. My only complaint is that I hear a fair amount of hiss when no signal is present.
Joseph H
Great BT adapter/amp
For the price the N3 can’t be beat. Distance, battery life, sound quality and volume level are all outstanding. Ive owned many little BT adapters before, but none of them were near the quality of this guy. This is my first fosi purchase, but I will definitely be purchasing more after buying this. Pure quality. 👍🏻
