Seamless System Integration
With optical and line outputs, it connects easily to DACs, amplifiers, or active speakers.
The included remote control allows convenient input/output switching and track selection.
A 12V Trigger output enables synchronized power with Fosi devices like ZD3 and ZA3.
Input: USB-A (USB flash drives), CD
Output: 3.5mm Headphones Jack, LINE, OPT, 12V Trigger
As Seen On
Precision CD Transport: Optimized servo system ensures accurate disc reading, smooth playback, and reduced wear, supporting stable long-term performance and consistent audio output.
All-in-One Audio Design: Combines CD player, DAC, and headphone amplifier in one unit, simplifying setup while maintaining low distortion and clear signal reproduction.
CD Ripping & USB Playback: Supports CD ripping to USB and direct playback, enabling easy conversion to digital files and convenient access without additional devices.
Flexible Output Connectivity: Multiple outputs support headphones, amplifiers, and active speakers, allowing seamless integration into desktop systems or larger audio setups.
ESP Anti-Skip Protection: 60-second buffering reduces interruptions from vibration, maintaining stable playback and improving reliability in movement or less controlled environments.
Chipset: SC6137D + CS43131 + TPA6120
Max Sampling Rate
  • CD: PCM 16bit / 96kHz
  • USB (USB flash drives): PCM 16bit / 96kHz
Headphone Impedance: 16–300Ω
CD Formats: CDDA, CD-R / CD-RW (partially readable). Original pressed discs are recommended
CD-R Formats: FLAC / WAV / WMA / AAC / MP3
SACD Playback: Only SACDs with a CD layer are supported
Formats for USB Drive Playback: MP3 / WAV / FLAC / AAC / APE / WMA
IR Remote Control: Supports a maximum operating distance of up to 7 meters
Input Voltage: DC 5V / 2A
Firmware Upgrade: Firmware can be updated online via a USB-A port using a USB flash drive
3.5mm Output Performance (CD)
Rated Output Power: L+R ≥ 210mW + 210mW (32Ω / THD+N < 1%)
SNR: 121 dB (A-weighted)
THD+N: 0.002% (A-weighted)
Dynamic Range: 121 dB
Noise Floor: ≤ 3µV (A-weighted)
LINE Output Performance (CD)
Output Level: ≥ 2Vrms
SNR: 124 dB (A-weighted)
THD+N: 0.0009% (A-weighted)
Dynamic Range: 124 dB
  • Merak
  • USB-A to USB-C Cable
  • IR Remote Control
Which Amp Is Right for You?
Fosi Audio BT20A
Release Date
2020
Channels
2.0
Bluetooth Chip
ATS2853
Amplifier Chip
TI TPA3116, NE5532
Max Output Power
100W × 2
Inputs
RCA, BT
Outputs
Speaker Out
≥ 98dB
≤ 0.5%
Input Switch
Auto Switch
Bass & Treble Control
Supported
Bluetooth
5.0: SBC, AAC
Other Features
Fosi Audio BT20A Pro
Release Date
2023
Channels
2.0
Bluetooth Chip
ATS2853
Amplifier Chip
TI TPA3225, NE5532
Max Output Power
300W × 2 @ 4Ω
Inputs
RCA, BT
Outputs
Speaker Out
≥ 108dB
< 0.005%
Input Switch
Auto Switch
Supported
Bluetooth
5.0: SBC, AAC
Other Features
From $249.99
Fosi Audio BT20A MAX
Release Date
2025
Channels
2.0 / 2.1
Bluetooth Chip
Qualcomm QCC3095
Amplifier Chip
TI TPA3225, NE5532
Max Output Power
300W × 2 @ 4Ω
Inputs
RCA1, RCA2, BT
Outputs
SUB Out, Speaker Out
≥ 112dB
≤ 0.003%
Input Switch
Dedicated Switch Button
Supported
Bluetooth
6.0: SBC, AAC, aptX, aptX HD, aptX Adaptive, aptX Lossless, LDAC
Other Features
Remote Control, PFFB Technology, Bypass, High-Pass Filter, 12V Trigger, Motorized Potentiometer
What is the Fosi Audio Merak CD Player?
The Fosi Audio Merak CD Player is a compact, desktop-style Hi-Fi device designed to blend traditional CD playback with modern digital features.
How to check USB drive format?
Windows:
This PC
→ Manage
→ Disk Management
→ Check USB format
Supported:
✔ FAT32
Unsupported:
✘ NTFS
Recommendation:
Most new USB drives are preformatted as FAT32.
Does playback stop when opening the CD lid?
Yes.
Reason:
Merak uses Hall sensor detection.
Behavior:
Opening the lid during playback immediately stops playback.
Status:
✔ Normal design behavior
Does Merak meet environmental standards?
Yes.
Compliance:
✔ ROHS 2.0
✔ REACH
Does Merak support SACD?
Partial support.
Supported:
✔ CD layer only
Unsupported:
✘ SACD high-resolution layer
Why use a dedicated CD mechanism instead of a DVD mechanism to play CDs?
Dedicated CD mechanism is specifically optimized for audio playback, including a more precise clock system, a more stable reading structure, and an optimized digital signal path. Compared to a general-purpose DVD mechanism, it typically delivers clearer audio detail and a more stable soundstage performance.
Why is ESP anti-shock protection included in a desktop CD player?
Although ESP is more commonly used in portable devices, it is included for the following scenarios:
1. Users may use the device in a car, where vibrations can affect playback stability;
2. On a desktop, strong bass or high-energy music may still cause vibration that impacts disc reading stability.
Compact, well-built tabletop CD player praised for "superb" sound quality and versatile connectivity options. Customers loved the optical output, USB ripping capability, and gapless playback. Common praise: "great value," "excellent clarity," and "fantastic sound." Minor issues noted: track fade-in clipping, slow ripping speed, scratches on plastic lid, and occasional compatibility concerns with external DACs.
  • 5 stars: 181 (78%)
  • 4 stars: 37 (16%)
  • 3 stars: 5 (2%)
  • 2 stars: 3 (1%)
  • 1 star: 5 (2%)
Tim (Canada)
Perfect player
Love my Merak!!
So glad I boxed my cd’s up 20 years ago & kept them.
I’m having so much fun rediscovering my collection & the Fosi Merak cd player is a joy to listen to.
My system is a Merak into a ZD3 then into two ZA3’s & out to a pair of Klipsh bookshelf’s & matching sub…it sounds amazing.🤗
Thanks Fosi!!
Gilbert (United States)
Merak do Rock
I’m listening to cd’s again because of this merak cd player, gives a very good quality output music..worth the money, i even ordered fosi nano disc player for portability..they all have a good sound output to my speakers
Pinkie (Colombia)
Very good quality and very easy to use! with potential to be even better
I've been using the merak time to time and I can say that the disc and flash drive playback is so good, the sound that provides is very clean and it's particularly colored to any side. That being said, that can lead to having no mercy with bad or poor quality recordings, so that's where I would have liked to have a function where you could at least at least up or down the bass and the treble built in the merak itself and not having need for a pre amp to do that. Other than that, a thing that I'd change on the design itself it's the volume slider for a volume nob at the front, but obviously that would meant that you'd have to change the layout of the buttons at the front, and right there is where you NAILED, because it's so easy and simple to use just because of that, no weird button combos to access a funtion, all you need for non friction playback is right there and the maximum tricks that it has is only hold certain buttons for more that 2 seconds. And the last things I wanted to mention are:
The remote control and the screen
With the remote, I have no issues with it but ONE single doubt, why the buttons at the right and left bottom corners aren't given with any funtion at all and that's why I believe we could have some 2 funtions more for the player. And for the screen, I just think would be nice to have some text showing when playing files such as mp3 or flacs like the title of a song passing through the screen when starts to play, but those are just little nitpicks
In conclusion it's a fantastic products with an amazing sound and a really stunning build quality and a such a pretty design, keep pushing on that direction Fosi!
w
wilfen (United States)
Game Changer & Best in Its Class!
I’ll keep this simple. I was ready to be mildly impressed, but I was completely won over by this high-quality, stylish CD player.
In the past year I have tried and tested six different players by various makers, and Fosi Audio Merak is the undisputed pound-for-pound champion for my money. The playback has been flawless, excellent connectivity, straightforward controls including a well designed remote control, and the display is excellent.
If you’re looking for a solid and great looking player developed with real world users like you in mind, then I highly recommend the Merak.
I’ve been playing my favorite CDs on mine ever since it arrived. Enjoy your music and happy listening!
Alfred (United States)
Near Perfect!
This player performs amazingly well at any price point.
Ez (United Kingdom)
Great quality and value
JazzPirate (United States)
Great Player
Luis (United States)
Andrew (Australia)
Love my Merak CD Player
Anyway to the review.
AndrewT
Michael (United States)
The CD Player I was missing
DanR2C (United States)
Great product!
I did see some sound improvements from streaming, like the music was more full or had more data. It may also just be in my head if I’m honest hahaha regardless it has been amazing and I 110% recommend you get one.
It’s not perfect, that latch is a mess and should really have a magnet or even just a spring with some tension or a clip or something. It just feel loose and I’d it clicked or latched or clipped close, it will feel better.
I see no use for the USB and ripping a CD, like come one, I’m getting this so I have and use physical media, not as a device to have digital files and stream them from a home server or something, plus even I did that, with no Meta data, it’s like going back to 1999 and manually adding all this to files.
GP. (Canada)
The Fosi Audio Merak is one of those rare pieces that just works—and keeps working the way you expect. Sound quality is clean, detailed, and far more refined than you’d expect at this price. Whether through headphones or a system, it delivers a solid, enjoyable listening experience without fuss.
Where it really stands out is the overall experience around the product. Fosi’s customer service is responsive, helpful, and actually present—something that’s becoming rare. Questions get answered, support feels human, and you’re not left chasing solutions if you need help. That level of follow-through adds real value to the purchase.
The design is simple and well executed -well deserving the Red Dot Award, with the top-loading mechanism adding a tactile, satisfying touch. It’s compact, versatile, and does exactly what it promises without overcomplicating things.
Curt (United States)
Great little CD Player!
Tom (United States)
Exceeded all expectations
Julio (Spain)
REPRODUCTOR DE CD PORTATIL DE UNA GRAN CALIDAD
Lo primero decir que viene muy bien presentado en una caja muy bonita, lo he probado con auriculares primero reproduciendo un cd y después con un pendrive con formato flac y suena de maravilla. Después lo he conectado a un amplificador y lo he vuelto a probar con un cd y con el pendrive, decir que este reproductor suena tan bien como otros reproductores mucho mas caros, además es muy silencioso, lo recomiendo.
Max (United States)
Steven (United Kingdom)
Great little CD player
I love it, simple to use, great sound especially when paired with ZH3. Haven't used all the features like CD ripping but awesome for the cost
YOGESH (India)
Eric (Australia)
Great quality CD Player.
This small unit is well-equipped and finally allows me to play my CD collection without buying a large and expensive hifi setup. Well made and conveniently proportioned it fits my entrainment area great. Connected to my home theatre setup by optical, this sounds great.
