![[Old Version] 2 Channel Class d Stereo Mini Amplifier for Home Speakers 50W x 2 Audio Small Amp](http://fosiaudio.com/cdn/shop/products/61kAJDWo4CL._SL1000.jpg?v=1751598420&width=1000)
Fosi Audio V1.0 (Refurbished Unit)
Best for bookshelf/computer/desktop/speakers in your room, connect to your Phone/MP3 player/CD/TV/PC/Echo Dot as input, 50Watt X 2(4 ohms, 20 Hz - 20 kHz, 0.04% THD) can drive 2Ohm - 8Ohm speakers;
>Home Hi-Fi 2.0 integrated amplifier, Exclusively designed for the customers who pursue HiFi sound; Ship with power adapter and power cord, you can use directly;
Simple compact design but practical and powerful, Adopt TI TPA3116D2 chip to get clear and clarity sound, no audible noise, dead silent when nothing is playing through it;
Aluminum shell and Aluminum knob to sure high quality, 18-month warranty, you can return the item if you have any problems;
![[Old Version] 2 Channel Class d Stereo Mini Amplifier for Home Speakers 50W x 2 Audio Small Amp](https://cdn.shopifycdn.net/s/files/1/2251/7913/files/A__01_7e06d151-6fc3-4973-a0e3-15911361a62a.jpg?v=1637203577)
![[Old Version] 2 Channel Class d Stereo Mini Amplifier for Home Speakers 50W x 2 Audio Small Amp](https://cdn.shopifycdn.net/s/files/1/2251/7913/files/A__02_89870e94-a524-4d01-b3b2-26e4b323f74f.jpg?v=1637203577)
Specifications | Details |
Model | V1.0 |
Chip Set | TPA3116 |
Output Power | 50W x2@4Ω |
Terminating Impedance | 2Ω-8Ω |
Input Mode | RCA |
Output Mode | Passive Speakers |
Frequency Range | 20Hz - 20kHz (±1dB) |
THD | ≤ 0.04% |
SNR | ≥ 98dB |
Input Sensitivity | ≤ 280mV |
Device Dimension | 4.13 x 3.54 x 1.38 inches |
DC Input Range | 12-24V |
Power Supply | 19V 4.74A |
Item | Quantity |
Fosi Audio V1.0 Amplifier | x 1 |
19V 4.74A Power Adapter | x 1 |
User’s Manual | x 1 |
