  • Output: RCA, Sub Out
  • THD: <0.00012%
  • SNR: ≥121dB
  • Powe Supply: 5V 2A
  • Fosi Audio DAC-Q6 *1
  • USER MANUAL *1
  • 5 stars: 47 (82%)
  • 4 stars: 9 (16%)
  • 3 stars: 1 (2%)
Nick (United Kingdom)
Yankele (Ecuador)
Perfect companion for my V3
Peter (Hungary)
0
07VFDInLCD (United States)
Michal (Czechia)
Jeff (United States)
Solid DAC
Richard (South Africa)
Awesome little DAC
Got the Q6 to feed into my GR70 tube amp. Been using this combo with my HD600 headphones. I can’t imagine anything sounding better than this setup honestly.
Recently received the Q6 DAC and GR70 tube amp to power my Sennheiser HD600 headphones. Honestly I can’t imagine anything sounding better than this. Music is exciting all over again. Both the Q6 and GR70 are great little devices, nice build quality and excellent audio.
Genaro
James (United States)
Basic and nice
Kennith
Frederick (Philippines)
Finally!
Madeleine
surely
The speaker will be upgraded.
very good 👍
d
doug (United States)
Single USB Port
Would it be to much of an ask to have seperate power and data USB port's?
Steven (Canada)
Dylan (United States)
Great presence
Eric (Germany)
Very nice little DAC
Very nice straight forward DAC. Easy use, good build quality. Arrived in good packaging, in decent time from China.
P (United States)
Q6 DAC convertor
Perfect sound for a reasonable price.
No frills.
DANIEL (United States)
Just what I needed.
Well-packed, arrived on time, as described. Simple yet more than adequate. I needed just a dac as my dac's usb b input on my grant fidelity 09 was messed up but I still wanted to use the tube amp headphone out. Out of the box the sound was dull-no highs. Next, the mids became kinda scratchy. Then the mids became strident. Finally after about a day later, things smoothed out and it sounds great. This is the second time I've experienced a type of "burn-in" progression with an audio product. Both times it was a surprise. Sharing this to let people know patience is a virtue. I didn't test the other inputs nor the sub out as I only use it for out of my pc. Maybe some time later.
Nyofu (United States)
Fosi Audio Q6 Desktop DAC
d
david (United States)
Great value
Works perfectly for streaming audio from a iPad Pro to a hifi system. The sound is even better after rolling the op-amp chip with a discrete op-amp chip.
William (United States)
Sanjeev (India)
Good DAC
I was apprehensive when buying the DAC but on its arrival and connecting it on my system, made me realise what a good decision i made and what sound quality i was missing out on. The Q6 is a great option and i must say that it should have had a few more inputs like the 3.5mm jack and RCA alongwith simlar outputs too. somewhere if the DAC had a bluetooth for switching the different inputs like Optical, Coaxial and USb wld be better than the manual knob for switching, which makes the user get up and go to the system and manually change. All in all a great DAC with room for betterment.
DonnyJ (United States)
Super clean!
Got this for a micro pc build in my car came out sick but the mini pc was lacking good clean powerful signal and omg night and day when I installed this little beauty. Retired it from my car and use it to clean up a 20 year old Sony 5.1 home theater system put it in direct mode and let this baby give me a super clean signal for my main pc's 2.1 channel setup and the music is so clean it's hypnotic
DW (United States)
The perfect minimal DAC
There's something to be said for a functional device that performs above the price and comes with zero frills. That's this DAC. This DAC measures well, has enough inputs and outputs to where it just works well for a desktop amp or even a bookshelf stereo setup without problems.
Are there things I wish I had? Sure. A digital readout (or even LED indicators) for sample rate, separate USB C for data and power, and maybe the ability to pair with the Fosi remote that comes with other devices for selecting the input.
That being said... Right now I use it for my office stereo setup and it's just fantastic. I cannot recommend it enough if you don't need a ton of bells and whistles.
