High-Res Bluetooth Audio
  • Max Output Power: 300W × 2 @ 4Ω
  • RMS Output Power: 180W × 2 @ 4Ω
  • SNR: ≥ 112 dB
  • THD+N: ≤ 0.003%
  • Channel: 2.1
  • Chipset: TI TPA3255, NE5532
  • Input: RCA1 / RCA2 / Bluetooth
  • Output: Speaker Out / Sub Out
  • SNR: ≥ 112 dB
  • THD+N: ≤ 0.003%
  • Terminal Impedance: 2–8Ω
  • Bluetooth SoC: Qualcomm QCC3095
  • Bluetooth Device Name: Fosi Audio BT20A MAX
  • Bluetooth Version: 6.0
  • Bluetooth Connection Range: ≤ 15 m (50 ft)
  • Bluetooth Audio Codecs: SBC / AAC / aptX / aptX HD / aptX Adaptive / aptX Lossless / LDAC
  • Frequency Response: 20 Hz–20 kHz (±0.5 dB)
  • Voltage Range: DC 32 V–48 V
  • BT20A Max Power Amplifier x 1
  • Bluetooth Antenna x 1
  • User’s Manual x 1
  • IR Remote x 1
  • Power Adapter x 1
Which Amp Is Right for You?
Fosi Audio BT20A
Release Date
2020
Channels
2.0
Bluetooth Chip
ATS2853
Amplifier Chip
TI TPA3116, NE5532
Max Output Power
100W × 2
Inputs
RCA, BT
Outputs
Speaker Out
≥ 98dB
≤ 0.5%
Input Switch
Auto Switch
Bass & Treble Control
Supported
Bluetooth
5.0: SBC, AAC
Other Features
Fosi Audio BT20A Pro
Release Date
2023
Channels
2.0
Bluetooth Chip
ATS2853
Amplifier Chip
TI TPA3255, NE5532
Max Output Power
300W × 2 @ 4Ω
Inputs
RCA, BT
Outputs
Speaker Out
≥ 108dB
< 0.005%
Input Switch
Auto Switch
Supported
Bluetooth
5.0: SBC, AAC
Other Features
From $249.99
Release Date
2025
Channels
2.0 / 2.1
Bluetooth Chip
Qualcomm QCC3095
Amplifier Chip
TI TPA3255, NE5532
Max Output Power
300W × 2 @ 4Ω
Inputs
RCA1, RCA2, BT
Outputs
SUB Out, Speaker Out
≥ 112dB
≤ 0.003%
Input Switch
Dedicated Switch Button
Supported
Bluetooth
6.0: SBC, AAC, aptX, aptX HD, aptX Adaptive, aptX Lossless, LDAC
Other Features
Remote Control, PFFB Technology, Bypass, High-Pass Filter, 12V Trigger, Motorized Potentiometer
What functions does the remote control support?
The included IR remote can reset Bluetooth, switch inputs, control music tracks(in Bluetooth mode), and even control other Fosi gear(P4/ZD3/ZP3).
What should I do if someone else is connected to the amplifier via Bluetooth?
Press the RESET button on the remote to instantly drop the current connection, and clear the historically connected devices. Then pair your own device fresh (No Bluetooth reconnection function).
Can I listen to three audio inputs(Bluetooth and dual RCA inputs) simultaneously?
In TONE mode, the EQ controls are active, it can adjust the sound by treble and bass control. In Bypass mode, it bypasses the internal EQ, including treble and bass adjustments, to preserve the original audio signal output.
Customers praised this compact amplifier for "crystal clear" sound and impressive power, with one noting it "punches well above its weight." Highly rated for Bluetooth connectivity with LDAC support and driving various speakers. Some concerns about heat generation and audible fan noise at close range, though most find performance exceptional for the price.
  • 5 stars: 74 (84%)
  • 4 stars: 10 (11%)
  • 3 stars: 2 (2%)
  • 2 stars: 1 (1%)
  • 1 star: 1 (1%)
m
mike (United States)
Best reciever I have ever owned
Best reciever I have ever owned. Solid design, silent fan, and multi-device remote! Great sound!
Andy (United States)
BT20A MAX
Music at it's purest form Amazing little beast!
Henry (Canada)
excellent little machine
lots of punch in a small footprint!
Scottie (United States)
Budget powerhouse!
Got it paired with my Hifi rose rs201e all in one Streaming unit. Playing through a pair of polk r200 shelf speakers and a JBL L10cs subwoofer.
Incredible clarity and detail. One detail to add, make sure you get the 48v 5a power supply, to push the full potential of the amp! Definitely puts out Incredible sound and very low noise disturbance. What more can I say, I'm quite impressed!
Nate (Australia)
BT20A MAX Bluetooth Stereo
I’ve been really impressed with the Fosi Audio BT20A MAX. It paired surprisingly well with my vintage speakers and brought them to life with a warm, clean, and powerful sound. Plenty of volume, good bass control, and very clear mids/highs without sounding harsh. For the size and price, it exceeded expectations and works great for anyone running older speakers in a modern setup.
m
maddin (Germany)
Guter Verstärker mit toller Leistung und hochwertigen Bluetooth Codec wie LDAC
Kompakter, sehr gut verarbeiteter Verstärker mit überraschend viel Leistung.
Klingt sauber, dynamisch und ausgewogen – selbst bei höherer Lautstärke bleibt er kontrolliert.
Bluetooth funktioniert zuverlässig (inkl qualitativ hochwertigem LDAC) mit ausreichender Reichweite und die Klangregler (Bass/Treble) machen das Gerät deutlich flexibler für verschiedene Lautsprecher und Räume.
Auch der motorisierter Lautstärke-Regler ist ein Vorteil wenn man zwischen der Regelung am Gerät sowie der Fernbedienung wechselt - man sieht immer wo der Regler tatsächlich steht.
Für den aufgerufenen Preis ein prima Verstärker!
Elias (Mexico)
Excelente Amplificador
Excelente amplificador. Lo adquirí desde su lanzamiento y lo he usado constantemente desde entonces, y la verdad me ha encantado. Venía del modelo BT20A Pro y este se siente como una mejora clara en control, claridad y desempeño general.
Desde el primer momento se nota un sonido más limpio, con mejor separación de instrumentos y un grave más firme.
Uno de sus puntos fuertes son las funciones adicionales. El Tone Bypass permite una señal más pura cuando se desea, las dos entradas RCA son muy prácticas para múltiples fuentes, y el filtro de graves ayuda mucho a integrar el subwoofer de forma más controlada y sin saturación.
También destaca su capacidad para mover bien los altavoces, manteniendo control incluso a volúmenes altos sin distorsión evidente.
Visualmente es compacto, limpio y moderno, encajando perfectamente en cualquier setup.
En resumen, es una actualización muy bien lograda que combina buen sonido, funcionalidad y diseño. Totalmente recomendado para quienes buscan un amplificador compacto pero con rendimiento serio.
Steve
Surprising quality and power for its size. And when connected to the ZD3 DAC from the same brand, it's a winning combination. Of course, it's better with a 48 V power supply. It has nothing to envy of more renowned and larger equipment. The seller, unbeatable.
Brutally (United States)
Brutally good sound!
At the heart of my system is the Fosi Audio ZH3 DAC and Fosi Audio BT20A MAX power amplifier, forming the core of a clean, high-output 2.2-channel setup. The ZH3 handles digital conversion and preamp duties, while the BT20A MAX delivers strong, controlled amplification with excellent dynamic headroom. They are seated on a brutalist style end table from the 1960s. This table weighs over a 100 pounds and acts as a sound damper as well.
The amplifier drives Quad 12L bookshelf speakers, supported by dual PreSonus Eris Sub 8BT 8-inch powered subwoofers for extended, well-integrated low-frequency performance.
Signal sources include an iPhone connected via USB-C, streaming TIDAL and a library of over 7,000 lossless CD-quality tracks on Apple Music, along with a Fire TV for movies and streaming content.
Connections are upgraded with Nakamichi Excel Series 24k gold-plated banana plugs, and both the amp and subs use heavy-duty power cords. The entire system is powered through a Black Lion Audio PG-P Portable Power Conditioner for clean, stable power delivery.
Acoustic treatment is handled by TroyStudio 12" x 12" x 4" broadband acoustic foam panels mounted directly behind the seating position at ear level to control rear-wall reflections and enhance imaging clarity.
For video, the setup includes a ViewSonic M2 1080p portable projector paired with a QualGear 100-inch fixed-frame 16:9 4K Ultra White projection screen (1.2 gain), creating an immersive large-format viewing experience.
The result is a streamlined, Fosi-centered system delivering strong stereo imaging, dynamic impact, and cinematic scale in a medium-sized room — a compact but dynamic 2.2-channel system focused on clarity, controlled low-end, and strong stereo imaging. The sound from this amp is brutally good!!!!! Fosi I sent you a resume because I want to work for you and sell your amazing audio equipment!
Evan
Very good
BAS (United States)
Perfect Fit
I had a fairly specific need. The BT20A Max is exactly what I was looking for. I have a very small shelf with a turntable on a shelf below it. Rack sized audio equipment would fit but it did not allow me to move my rear-ported bookshelf speakers away from the wall. I needed something small, with phono inputs or multiple inputs, enough power to push my inefficient rear-ported speakers, Bluetooth and remote control. I have a subwoofer to go with the bookshelf speakers. The BT20A Max has a sub out and it has an 80 hz frequency filter. I am over the moon happy with this little amp. It doesn't have a phono line input but it does have multiple inputs so I was able to purchase the highly rated Box X5 phono preamp to fill all of my needs.
The elephant in the room needs to be addressed. Yes it has a fan. Yes it is BARELY audible at very low volume. Is it a distraction? NO. I have very sensitive hearing. It's a blessing and a curse. Too many reviewers talked about the fan noise and I have to admit, I was a little concerned. I do not do any near-field listening with my setup so I felt pretty confident that the soft fan sound would not be an issue. I feel like you would have to be sitting right next to the amp and be listening at very low level to even hear the fan. Do not let it stop you if you are leaning towards purchasing this little powerhouse amp. I went with the 48v power supply because of my inefficient speakers.
There is so much positive feedback I have for the Fosi Audio BT20A Max. Just buy it.
f
fede (Italy)
Ottimo apparato
Very good
HK (Canada)
Excellent Product With A Couple Of Issues
Where to start? First the good. This is an amazing product in a small package. The bass management is well implemented, the tone bypass is appreciated. The styling is very understated yet attractive, and the power is more than adequate especially with the larger power supply. It has the capability to make my speakers disappear leaving only the music; you can’t ask for much more than that in an audio product.
I’d like to see a couple of small additions to the design. I wish there were a couple of LEDs on the front panel to indicate when the Tone Bypass and the High Pass Filter are engaged. There is no indication now at all.
Now the bad. On the first unit I received the switch for the HPF and the power input were not flush with the back of the case. In fact they were pushed so far in that the HPF switch could not be activated at all. Now the worse: even though I sent a picture and description of the issue to them, their first reaction was that they could not see a problem. It wasn’t until I sent another detailed photograph comparing the back of a unit on their website with the one I received that they acknowledged the issue. Then, their first solution was for me to open the case up and try to fix it myself. When I said this was not satisfactory as I have neither the tools or the expertise, they agreed to send another one to me. I agreed to this, and was prepared to send the defective one back. I received a tracking number for the replacement and a link to a website. Unfortunately the site was entirely in written Chinese which unfortunately I can not understand. The only thing I could see was shipping dates and it was apparent that nothing was on its way to me. When I followed up I was informed that they were out of stock. I could go on about not being able to understand the shipping website, the inability to contact the actual shipping company, or the fact that when the unit did show up the website indicated that it had been received and signed for when in fact I did not even know it was here and had been placed against an outside door that isn’t in use. I won’t even mention the emails I received during the interim enquiring if I had sent the original unit back yet.
Now the epilogue: The replacement unit I received has the same issue of the HPF switch and power input not being fitted correctly into the case. Obviously there are some teething pains on the production line. At this point I give up. Even though the replacement has the same problem it is not to the same degree; the HPF switch can be activated, so I am just going to live with it. It didn’t cost a huge amount of money, and I really am very impressed with the performance.
Tony (Canada)
BT20A Max
Excellent Amp, perfect works with my 25 years old Mission speaker.
DGJ (The Netherlands)
Great
Great product. Use the BT20a Max in combination with my new Dali SP speakers.
Noah’s (United States)
Great amplifier!
It’s really powerful and works great for what I need, especially the high pass filter and Bluetooth functions. Just wish it was a bit cheaper, I had the promo code saved but completely forgot to use it. Great product!
Craig (United States)
Solid upgrade from ZA3
The dynamic range of the BT20A MAX is a noticeable improvement over the ZA3 it replaced. Bluetooth worked well. The remote appears to be a remote for multiple Fosi products. Pay attention to the buttons on the remote to know which ones work for the BT20A. They are labeled. Wish this had a phono input like the ZA3. That's my only criticism thus far. Overall, very pleased.
Omar
I belong to a typical user.
The analog amplifier i used before guarantees many functions and sound quality, but i learned from years of experience. I wanted to listen more comfortably, so i often connected it to a bluetooth speaker rather than an amplifier. After testing, this product supports seamless bluetooth and supports aptx lossless to connect lightly, but it guarantees quite good sound quality.
The exterior is also simple and luxurious with an aluminum body.
I am also very satisfied with the power that will remain even after ringing all the kef passive speakers i have.
If you want to listen to music conveniently, i recommend this product.
Todd (United States)
Little amp, big power
I’ve have my Fosi BY20A Max hooked up to a pair of definitive outdoor speakers and a small definitive subwoofer and it sounds amazing. Cannot beat the price. I like the fact that it is small and portable thinking about grabbing a couple more for different parts of the house. I would definitely recommend this product. It would be nice if the labels for the controls were more visible. A bigger It would be nice if the labels for the controls where more visible. A bigger font and possibly placed above the knobs would be better to see.
