- 【Multiple Funtions】Supports USB, Optical, Coaxial, 3.5mm AUX and Bluetooth 5.0 apt-X input, Infrared receive & OLED display. Note: It is highly recommended that you use this amplifier on a 4ohm speaker.
- 【Hi-Fi Performance】Adopt Bluetooth QCC3031 & USB CM6642 chips, support aptX, aptX HD & 24bit/192Khz audio; High gain antenna for long range streaming up to 65 ft(20m).
- 【Great Sound】Class d amp 50Watt x2@4ohm power with low-pass subwoofer output can drive most home speakers, TI NE5532 operational amplifier cores to ensure sound quality.
- 【Remote Control】Multifunctional remote control for home wireless use with bass and treble control, inputs selector, EQ, mute, loudness setting, etc.
Specifications | Details |
Model | DA2120A |
Output Power | 50W + 50W @4Ω |
Terminating Impedance | 2-6 ohm (Recommended 4ohm) |
Input Mode | Bluetooth 5.0 support aptX, AUX, USB, Optical, Coaxial |
Output Mode | Passive Speakers + Active Subwoofer |
Frequency Range | 20Hz - 20kHz |
THD | ≤ 0.01% |
SNR | ≥ 105dB |
Input Sensitivity | ≤ 280mV |
USB Input Sampling Frequency | 192kHz/24Bit |
Optical/Coaxial Input Sampling Frequency | 192kHz/24Bit |
USB System Supported | XP/W7/W8/W10/MAC/Linux |
Bluetooth Transmission Distance | 65ft |
Bluetooth Name | FOSI AUDIO |
Device Dimension | L134*W130*H34mm |
Power Supply | 24V/4.5A |
Item | Quantity |
DA2120A Amplifier | x 1 |
24V 4.5A Power Supply | x 1 |
Remote Control | x 1 |
USB Cable | x 1 |
Optical Cable | x 1 |
AC Cord | x 1 |
User’s Manual | x 1 |
DA2120C+32V Bluetooth Amplifier 2.1CH 120W x2
