  • Input Mode: MM+MC RCA
  • Output Mode: RCA
  • THD: ≤0.009%
  • SNR: ≥ 92dB
  • Power Supply: 16V/1A
  • BОX X5 Phono Preamp x 1
  • 16V 1A Power Adapter x 1
From $39.99
Active Speakers + Headphone
Bass & Treble Control
≥ 70dB
≤ 0.08%
12V/1.5A
From $69.99
RCA+3.5mm
Active Speakers
≥ 98dB
≤ 0.1%
12V/1.5A
Fosi Audio Box X3 Bluetooth Vacuum Tube Phono Preamp - Fosi Audio
From $59.99
Bluetooth + AUx+ RCA
Active speakers
≥ 70dB
≤ 0.1%
12V/1.5A
From $89.99
RCA+3.5mm AUNo
RCA+3.5mm AUNo
≥70dB
≤ 0.1%
12V/1.5A
Customers praise this phono preamplifier for exceptional sound quality, quiet noise floor, clean bass, and crisp highs at a remarkable value. "It delivers impressive audiophile performance well above its price tier." The compact design offers MM/MC capability with variable gain (39-66dB). Some noted humming issues and a bulky power supply, while one customer reported delivery problems.
  • 5 stars: 106 (90%)
  • 4 stars: 8 (7%)
  • 3 stars: 1 (1%)
  • 2 stars: 1 (1%)
  • 1 star: 2 (2%)
It works very well!
Meu (Brazil)
Excelente
O Fosi Box X5 melhorou muito o som do meu toca-discos (eu estava usando o pré de phono embutido)!
Infelizmente não consegui me livrar do "humming", aquele ruído de fundo, mas mesmo assim valeu a pena, é um excelente custo-benefício.
O review completo do Box X5 está disponível no canal Meu Áudio.
Peregrine (United States)
Satisfaction with my Box X5
I purchased the Box X5 phono pre-amp together with the LUNA3 turntable. The Box X5 arrived promptly while I had to wait a couple of weeks for the LUNA3. Once the turntable arrived I unboxed everything. All the components arrived in excellent condition. Installation of the Box X5 and turntable was simple. My only comment is that the ground post is not where I would have expected it, but I’m sure Fosi has their reasons. The RCA cord supplied with the turntable included the grounding wire and there was sufficient length for it to easily bridge the distance to the terminal.
Peter (Hungary)
Great quality phono preamp
GibH (United States)
Big sound in a small package
This is a great phono stage for its price. If youre looking for just great sound to actively listen to music on your turntable through good speakers, this is it. If you deem yourself an audiophile (you know, the pretentious type), this product still hits way above its weight and produces great sound for you too. Please dont be fooled, this is really all one needs to achieve very, very, good sound from their music (given they have a decent setup). But if you’re searching for exceptional, heavenly, sonic accuracy (which is a farce), a wide soundstage, airiness, and bragging rights, then throw a couple thousand dollars at another phono stage so you can test ad nauseum the quality of your equipment rather than enjoy good music. Fosi X5, Great product.
Daz (United States)
Fosi Audio Box X5
Partnered this with a Rega Planar 3 RS and an Arcam A5+, I was floored by what I was hearing! Listening to Tears in Heaven from Eric Clapton Unplugged, I had to listen to it a second time. I was hearing things I’d never heard before and had the sensation they were in the room with me. I can definitely recommend one.
Zlatri (Sweden)
Phono Preamp
Karl (France)
What else?
Petter
Works well
Paulie (United States)
Great Phono Preamp
My Audio Technica TT has a built in phono preamp which gets the job done. However, the audio tends to sound low and diminished at times depending on the music style. I bought the X5 to bump the gain just a hair to my speaker amp and man it does not disappoint. It gives me exactly the bump my TT needed. Sound quality is fantastic with a beautiful soundstage. The ground attachment is perfect. I don’t have any hum/static/distortion. I would buy the X5 again and highly recommend it. Cheers!
Chuck (United States)
Immaculate!!
Hreinn (Iceland)
Anonymous (Czechia)
A great little box
Matches my Fosi power amp for a clean, compact look. I love the power supply which uses an inline transformer instead of a bulky ‘wall wart.”
Anonymous (Canada)
Great sounding phono pre amp
I can only attest to the mm pre amp features of this amplifier. It sounds great even compared to others I've tried in a higher price class. Delivers an accurate representation and a very clean sound.
Andreas (Norway)
Box X5 has fives time value.
The title is more or less a an exaggeration. Though credit is due where credit is due - this little device does a lot of work. My turntable has an integrated RIAA stage which works fine. after listening to some of my favorite records i have discovered more sound.
Aaron (United States)
Excellent
For the price I can't imagine a much better product.
Sarah (United States)
Best Bang for the Buck!
The Fosi Audio Box X5 stands out as an exceptionally budget-friendly phono preamp that delivers impressive audiophile performance well above its price tier. It has a remarkably quiet noise floor, which eliminates background hiss and hum, allowing for crisp, punchy bass and wide instrument separation.
Robert (United States)
Replacing a 50 year old custom built preamp
I’m restoring another turntable SME/Empire and needed a second RIAA phono preamp. Got the Fosi X5 and liked it so much I’m using it on my main system in place of my 50 year old custom unit.
Ted
X5 & my vinyl records.
This preamp changed the sound of every vinyl album I have played so far. The improvement is beyond what I expected.
I have more trebel and bass notes than before. My turntable was connected to my existing amp through it phono in preamp.
Now I have the X5 plugged into an auxiliary input. This set up was easy and resulted in exceptional sound.
I highly recommend the Fosi X5 preamp.
Jayden (United States)
Anonymous (Australia)
Great
This is a well designed little set. Works well and sounds perfect.
Stephan
John
Great product.great value
