Fosi Audio TB20A TPA3116D2 Stereo Amplifier 2.1 Channel Class D Audio Amp with Subwoofer Volume Control
Prix habituel
$79.99 USD
Prix soldé
$79.99 USD
Prix habituel
$79.99 USD
Quick tips:
2. The amp will off when you switch off, but it’s normal that the power LED light stay on even switch off, the power LED light on means the power supply in.
3. What will cause noise?
Poor quality audio cables, Sound source, Speakers, Other interfering signals;Incompletely connections.
Unplug the RCA cable, connect this amp to speakers, and then plug into the power supply, power on and volume on, hear whether noise exists on speakers, if noise existed, the noise may from speakers or amp, so you need to change speakers for further confirmation. If no noise the noise may from the audio source.
Parameter:
1. Power supply range: 12v-25v;
2. THD: ≤ 0.04%;
3. Frequency Range: 20Hz - 20kHz (±1 dB);
4. SNR: ≥ 98dB;
5. Input sensitivity: ≤ 280mV;
6. Terminating impedance: 2Ohm - 8Ohm;
7. Output power: 50W + 50W + 100W Sub;
8. Input mode: Analog;
9. Power supply: 19V 4.74A 90W;
10. Supplied Accessories: Amplifier, Power supply, AC power cord, Manual.
