Reviews are in...
Alt image
Alt image
The V3 monoblocks’ overall attitude is quite energetic and upfront. It means the Fosi Audio is never less than an engaged and engaging listen.
It is incredible how far these small amplifiers have come. It is the result of a manufacturer listening to our needs.
Fosi created a unit with much better driving power, a much better sonic quality, improved resolution, and a wider sound with inherently better separation and lower background noise.
The V3 Mono form factor feels unapologetically tiny. And, for anyone seeking a stealthy amp to pair with their desktop speakers, this one will be hard to beat.
Hear what they are saying
It is my pleasure to recommend Fosi Audio V3 Mono amplifier.
All l can say is wow! It is incredible how far these smallamplifiers have come, lt is the result of a manufacturer listening to our needs,implementing features such asbalanced and trigger inputs,and proper feedback mechanism to essentially eliminate load dependency.lcan't imagine asking for more from Fosi when it comes tosuch an amplifier. Everything is as good as you could possibly want, it is my pleasure to recommend Fosi AudioV3 Mono amplifier.
Another Milestone Amp Crafted for Audiophiles
In 2023, following the launch of the V3 stereo amplifier, we received numerous valuable suggestions and feedback from our users.
There are still points to be improved, such as the adoption of PFFB, but I expect further improvements in the future. --Toku from ASR
It would be great if there was the PFFB, as Toku mentions, also no load dependency --ModDIY from ASR
With balanced inputs and volume bypass ... this amp will be killer, even with a higher price tag (under 200 USD?) --mike70 from ASR
I wish that they offered a mono block version (based on the V3). No volume pot. Simplified signal path. --markg4331 from Youtube
I would have preferred a toggle on/off switch instead of the on/off switch being integrated on the volume pot. --cyclo from ASR
We listen intently, record diligently, and develop with dedication, ultimately striving to transform your suggestions and ideas into reality—the V3 mono.
PFFB Load Independence
Swappable Op-Amp Design
240W Rated Power Output
All-Aluminum Alloy Chassis
Full-Body Cooling Design
XLR Input
RCA Input
XLR Input
RCA Input
PFFB Post-Filter Feedback Technology
Significantly reduces distortion, enhances linearity and frequency response, and improves sound purity and system efficiency.
Reproducing the Purest Sound
Recreating Every Detail
Effectively reduces the output impedance, thereby increasing the damping factor for tighter and more precise speaker response.
Load Dependence Defeating
Overcoming the Pain Point of Class-D Amps
Reduces output filter impact, boosts frequency response for balanced, natural tones, ensuring true reproduction.
Crafts an enriching, immersive sound experience, satisfying your craving for superior musical quality with unmatched audio richness.
Pure Sound, Accurate Imaging
with Zero Crosstalk
Enhances stereo depth and soundstage accuracy through precise power and channel separation
for a purer audio experience.
Compact and Exquisite
With Minimalist Design
Effortlessly integrates into various settings like home theater, study room, desktop and studios without occupying too much space.
Sturdy and Durable
Durably built from a single CNC-machined aluminum alloy piece, showcasing a robust and refined high-quality design.
Premium Internal Components
Carefully selected top-tier components are dedicated to crafting extraordinary sound quality,
making every listening a pure delight.
Japanese NICHICON
63V/2200μF Filtering Capacitors
Eliminates the poor contact issues of traditional physical switches, ensuring stable and pure sound transmission.
German WIMA
Coupling Capacitors
Japanese Sumida
SMD Inductors
Offer superior signal purity and noise reduction, elevating the amplifier's sound performance.
ELNA, Japan
Audiophile-Grade Capacitors
Ensure enhanced audio clarity and stability, contributing to a richer sound experience
Japanese NICHICON
German WIMA
Coupling Capacitors
Japanese Sumida
SMD Inductor
ELNA, Japan
Flexibility
Adaptable to Various Scenarios
Offers enjoyment across various settings, from home theaters to professional studios, ensuring a versatile music experience.
CONVENIENCE
Supports XLR Balanced and RCA Inputs
Easily Switchable with a Toggle
Provides you with flexible connectivity options that are easily adapted for both home and professional scenarios.
XLR Balanced Input
Enhanced Interference Resistance
Ensures stable audio transmission for a precise, clear listening experience, fulfilling the quest for supreme sound quality.
RCA Input
with 25dB and 31dB Gain Selection
Enhances source adaptability and audio clarity, reducing distortion and overload risk, suitable for various audio setups.
FEATURES
Easily replaceable DIP8 dual discrete op-amps, meeting your pursuit of a personalized audio experience.
Four-Layer PCB Design
All for Superior Sound Quality
Boosts signal stability and audio purity, enhancing performance and interference resistance for superior sound output.
Auto Standby Mode
High Energy Efficiency
Automatically enters standby after 10 minutes of no signal input, extending device lifespan and reducing power consumption.
Advanced Cooling Design
Guarantees long-term efficient operation of the amp, prevents overheating,
and maintains consistent sound quality and device longevity.
Side Ventilation
More Effective Cooling
Boosts heat dissipation efficiency for superior performance and stable sound quality, ensuring enhanced air circulation.
Dust-Proof Filter Screens
Aesthetic and Practical
Effectively blocks dust without compromising cooling, ensuring long-term stability and enhancing product durability.
Optional 48V/10A Power Supply
Provides stable and robust power support, ensuring high-fidelity sound
quality to meet diverse audio playback demands.
Powers Two V3 MONOs Simultaneously
With a power supply splitter cable, a single PSU can supply power to two amps, saving space and maintaining tidiness, offering you more flexible combination solutions.
Measurements
Channel: 1.0
Amplifier Chip: Texas Instruments TPA3255
Input: RCA, XLR, ¼" TRS
Output: Speaker Output (supports banana plug or bare wire connection)
SINAD: XLR: 101dB ; RCA: 93dB
SNR: ≥123dB
Dynamic Range: ≥123dB
THD: <0.006%
Gain: XLR/¼” TRS: 20dB ; RCA: 25dB, 31dB;
Terminal Impedance: 2-8Ω
Rated Power Output: 48V/5A--240W@4Ω ; 32V/5A --100W@4Ω
Frequency Response: 10Hz-30kHz(±0.06dB)
Input Voltage Range: DC 32-48V
Standard PSU: 48V/5A
Power Output with Various PSUs
PSU
Load Impedance
Rated Power
(1kHz, THD 1%)
Max Power
(1kHz, THD 10%)
4Ω
100W
130W
32V/5A
6Ω
65W
80W
8Ω
55W
65W
4Ω
240W
300W
48V/5A
6Ω
160W
200W
8Ω
120W
150W
