Fosi Audio i5
Open-Back Planar Magnetic Headphones
Buy Now
Thank you for subscribing!
2.1W+2.1W
High Power Output
0.0002%
Ultra-Low Distortion
PCM 384kHz, DSD256
High Sampling Rates
2.1W+2.1W
High Power Output
0.0002%
PCM 384kHz, DSD256
High Sampling Rate
Gaming DAC Headphone Amplifier
Fosi Audio i5
Buy Now
Fosi Audio i5 Open-Back Planar Magnetic Headphones
Fosi Audio i5
Immersive Listening
Pure Original Sound
Crafted with an ultra-thin diaphragm using nano-level technology, an invisible high-powered magnetic system, and precision acoustic design, the i5 delivers high resolution and low distortion for a truly lifelike listening experience.
Planar Headphones
Fosi Audio i5 Planar Headphones
  • Ultra-Large Diaphragm
  • Sputtered Coating
  • Magnetic Matrix
  • Acoustic Mesh
97mm Ultra-Large Diaphragm
The ultra-thin diaphragm, crafted with nano-level precision, delivers faster response, enhanced detail, and a more natural, clear, and layered sound.
Sputtered Coating
Sputtered Coating Technology
Utilizing advanced targeted sputtering technology, a highly conductive silver metal voice coil as thin as 1.3μm is precisely coated onto the diaphragm. This process significantly enhances sound refinement while ensuring durability, keeping excellent audio performance consistently stable over time.
Magnetic Matrix
Symmetrically Arranged High-Strength Magnetic Matrix
Each driver unit features 22 pieces of N50-grade neodymium magnets arranged symmetrically, ensuring precise and stable diaphragm vibration. This design enables accurate and swift dynamic response, effectively reducing nonlinear distortion to produce purer, more natural sound, faithfully reproducing the essence of music.
Acoustic Mesh
Rigid High-Transparency Acoustic Mesh
The high-transparency rigid rear mesh structure provides stable air pressure damping and linear feedback. It smooths out frequency spikes and reduces nonlinearity, achieving an open, airy soundstage with ultra-low acoustic resistance.
Ergonomic Design
Long-Lasting Comfort
Designed to follow the natural contours of the head, the i5 ensures a secure yet gentle fit. Even during extended listening sessions, it remains comfortable and pressure-free, letting you enjoy your music without distraction.
What is a planar headphone
Your heading text goes here
Dual-Axis Ear Cup Arms
Allows seamless vertical and horizontal rotation for a custom fit to different head shapes, enhancing both comfort and stability.
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Stepless Silicone Adjustment
The headband features a silicone adjustment slider with a damped, smooth feel, enabling easy and precise positioning based on personal preference.
Durable Memory Metal Headband
Made of high-strength memory metal, the headband maintains its shape over time. Lightweight and flexible, it reduces pressure and enhances comfort.
Breathable Skin-Friendly Earpads
Crafted with perforated leather and breathable fabric, the earpads stay cool and soft. Memory foam inside ensures all-day comfort without overheating.
Breathable, Skin-Friendly Earpads
Refined Craftsmanship
Where Aesthetics Meet Quality
A refined fusion of premium materials and elegant design, delivering a look that exudes sophistication, texture, and distinctive character.
Are Planar headphones better?
Genuine Suede Leather Headband
Soft and refined for a more comfortable fit.
High End Planar Magnetic Headphones
Luxurious Walnut Wood Frame
Each pair features a unique natural grain.
CNC-Machined Aluminum Frame
Lightweight yet sturdy with a metallic finish
S-Shaped Decorative Accent
Elegant and flowing, inspired by musical notes
Detachable Cable Design
The i5 features a detachable cable design with standard 3.5mm connectors on both sides, and is compatible with our available 3.5mm and 4.4mm headphone cables.
Fosi Audio i5 features
Reviews are in...
I was left impressed with Fosi Audio's new i5 planar magnetic headphones. It is a meaningful upgrade from any budget design sonically and also offers superlative build quality and finish.
All in all, the Fosi Audio i5 presents itself as a competitive alternative to established planar headphones. If you value technical precision, neutral tuning, and the ability to make personal sound adjustments (without altering the sound character), then the Fosi Audio i5 is a suitable headphone.
Now the i5 truly does it all, and I can safely recommend it for everyone looking for an open-back under $1000 USD. It will be a good deal even after the early-bird period, and I can’t wait to see what Fosi can do in the future.
Fosi Audio’s i5 is a wonderfully built, comfortable headphone with fantastic resolution, excellent tuning, and a product worthy of its planar moniker. The bass is handled extremely well, and the thoughtful tuning should leave most listeners completely satisfied like a Snickers.
Post a Review
Get a $100 Gift Card
Fosi Audio ZD3
Limited-Time Savings
Studio-Perfect Sound Complete HiFi Headphone Solution
Bundle & Save
Fosi Audio i5
What's in the Box
