Gaming DAC Headphone Amplifier
Fosi Audio K7
Hi-Res
Flagship Chipset | Tone Tuning | Balanced Output
Buy Now
Fosi Audio K7
Hi-Res
Available from 8th April!
Buy on Fosiaudio
2.1W+2.1W
High Power Output
0.0002%
Ultra-Low Distortion
PCM 384kHz, DSD256
High Sampling Rates
2.1W+2.1W
High Power Output
0.0002%
PCM 384kHz, DSD256
High Sampling Rate
Born for HiFi and Gaming
Poster
The K7 is a versatile gaming HiFi DAC/headphone amp, developed based on in-depth feedback from over a hundred HiFi and gaming enthusiasts. It supports mainstream digital inputs like USB, optical, and coaxial, and is equipped with aptX HD lossless Bluetooth codecs.
The K7 also features a microphone input with noise reduction, ensuring your voice is heard clearly online. Perfectly compatible with PS5 Pro, PS5, Switch, PC, Mac, tablets, TVs, and projectors, the K7 offers balanced headphone and line outputs. It easily handles music listening, gaming, work, live streaming, and multimedia needs. With its compact design and rich functionality, the K7 ensures an exceptional listening and gaming experience.
Reviews are in...
Poster
Poster
Why K7 DAC/Amp?
HiFi and Gaming,
Headphone Amplifier
Pure Music Enjoyment
Best Gaming DAC K7
Gaming Entertainment
Best Gaming DAC K7
Best Budget DAC
Audiophile-Grade Chipset
Best Budget DAC
DAC Bluetooth Amp
Comprehensive Digital Inputs
with Versatile Outputs
DAC Converter
3.5mm
Single-Ended Headphone Output
Rated Power
≥600mW+600mW @32Ω
4.4mm
Balanced Headphone Output
Rated Power
≥2.1W+2.1W @32Ω
3.5mm
Microphone Input
Best Bluetooth Amp
Hi-Res
Bluetooth Codecs
Under 40 ms
Imperceptible latency
Lossless PCM 24bit/48kHz
Sampling Rate
1.5-Inch LCD
High Definition Display
User-Friendly and
Practical Control Design
Best Desktop DAC
Tactile Shortcut Buttons
Best Desktop DAC
Best Desktop DAC
Angled Ergonomic Design
Best Desktop DAC
Connection Diagram
All-Aluminum Alloy Body,
with CNC Integrated Design
Best Headphone Amplifier
Best Budget DAC
Best Gaming DAC
Fully Balanced Circuitry,
0.0002% Ultra-Low Distortion
Multiple LDO Regulators
Ensuring Clear Sound Quality
Application Scenarios
General Specs
Chipset
Maximum Sampling Rate
USB:PCM 384kHz-32bit/DSD256
Optical: PCM 24bit/192kHz
Coaxial: PCM 24bit/192kHz
Bluetooth:PCM 24bit/48kHz
Headphone lmpedance
16-300Ω
Firmware Upgrade
Bluetooth Version
5.0
Bluetooth Connection Distance
≤13m
Noise Floor
≤2.5μV
Input Voltage and Current
DC 12V 2A
USB Compatible
Devices
Audio Parameters
4.4mm Balanced Headphone Output
Rated Power Output
121dB
<0.0002%
Dynamic Range
121dB
Noise Floor
≤ 6.5μV
Rated Power Output
122dB
0.0005%
Dynamic Range
121dB
Noise Floor
≤2.5μV
Frequency Response
20Hz-20kHz (±0.1dB)
RCA Output
Output Level
≥2Vrms
20Hz-20kHz (±0.1dB)
0.0005%
Dynamic Range
121dB
Noise Floor
≤3μV
Frequency Response
20Hz-20kHz
Packing List
