  • 100% Shielded Cables: Ensures the integrity of signal transmission, minimizes crosstalk, and safeguards the internal conductors.
  • Gold-Plated RCA Connectors: Offer superior conductivity, are resistant to oxidation, and stand up to corrosion.
  • Versatile Compatibility: Works with a variety of devices that have RCA inputs and outputs, such as amplifiers, preamplifiers, turntables, active speakers, and so on.
    0.3m/11.81in Length: Streamlines your desktop setup and facilitates easy connections.
  • When used to connect the Fosi Audio BOX X5 phono preamplifier to a turntable, it effectively mitigates electromagnetic interference.
Based on 5 reviews
80%
20%
John Clark
Nice cables
They look fine, they appear to be quite well made, and they work.
Cesar
Buenos cables
Buenos cables, de percepción de calidad en los materiales. Los largos son los adecuados para un escritorio o los cortos adecuados para su uso en rack. Forro de tela.
Oliv Thacker
Great cable
it does what cables should!
Marko Filipovic
RCA cable
For this range, great stuff
Claude Brulotte
P3
Mon P3 est mort cause problème de bruit aide grésillement dans tout le système. Et quand je vous le dit a ma répondu très bien ,faire rire de moi wow
