  • 24V 4.5A Power Adapter Description:
    AC110V-230V input;
    DC 24V 4.5A output;
    Connector size: 5.5*2.5mm
    Power adapter for class d amplifier;
  • BOX X5 16V 1A Power Adapter Description:
    Input: AC 110V or 230V, 50-60Hz
    Output: AC 16V 1A (Only for BOX X5, do not use with DC-type amplifiers)
    Cable Length: 1.2 meters
    Plug Type: Matches the country of your delivery address
    Important Note: This power adapter supplies AC (alternating current) output, not DC. It is exclusively designed for BOX X5 and should never be used with other amplifiers requiring DC power to avoid damage.
Based on 9 reviews
89%
(8)
11%
Michele Cati
Great!!!
I love your products!!
g
gerard Miró Jou
Todo perfecto
Bien empaquetado. buen estado y buena calidad y el enchufe adecuado
Matthew A Taylor
Just got it today
Sounds great. Got it hooked up to a fosi bt20a and a pair of jvc cherry wood speakers with ceramic cones and they sound almost as good as my Klipsch speakers.
T.J. Galiardo
Fosi Audio 24V 4.5A Power supply for TDA7498E TPA3116 TAS5613 Amplifier
Dmitry
Audibly noisy
Got it as a replacement for TB10A, and I can hear the power supply. Yeah it's faint, but when it's on your desk you can hear it, and it gets annoying. When it's just plugged into the wall it's a faint fast clicking sound, not too loud, but when you plug it into the amp it's a high frequency whine.
I have two other Fosi power supplies from similar amps and same specs, and they are absolutely silent, you can't hear anything, even when you put them against your ear. I also have another cheap power supply that makes the same whining sound I was going to use originally, but thought that if I got a genuine replacement from the manufacturer it would be good as new, but apparently not.
