Fosi Audio BT20A Bluetooth 5.0 Amplifier 2 Channel Stereo Amp Receiver Class D Amplifier for Home Audio System - Fosi Audio
$79.99 USD
$79.99 USD
$79.99 USD
Fosi Audio BT20A Bluetooth 5.0 Amplifier 2 CH
Power supply range 12v-24v
THD ≤ 0.5%
SNR ≥ 98dB
Input sensitivity ≤ 280mV
Bluetooth transmission distance 28ft
Terminating impedance 2Ohm - 8Ohm
Output power 100W + 100W
Input mode Bluetooth and Analog
Bluetooth Name Fosi Audio
Bluetooth chip ATS2853
Power supply 24V 4.5A
Amplifier 1
Power supply 1
AC power cord 1
User’s Manual 1
Download BT20A User Manual
Based on 33 reviews
79%
(26)
12%
3%
6%
J M MacCord
Great little amp
Finally got around to setting up this amp. I paired it with a cheap pair of Dual LE43PB outdoor speakers, a little speaker. Used a good speaker wire, 14g. They are 4-6 ohm speakers and I had to turn up the volume a bit to get the sound level I wanted (indoor listening level 50-60 dB) but the sound I got was remarkable spacious and full of depth. Far better than I expected! Super easy setup and Bluetooth connection, I haven't tried the RCA connectors. This is intended for patio use and for that purpose I think it will be great!
Brian Walach
Perfect for Outdoor Speakers
I have a screened porch and ran speakers both on the porch and out to the yard. I wanted something to play audio from the TV and to be able to play music from my phone. This was exactly what I was looking for. Works great and easy to set up. Small footprint as the power adapter is bigger than the unit itself, but this can be hidden. Bluetooth range is decent, maybe 40-50 feet before it starts to have trouble. The switch is great. TV plays on the speakers if it's on, Bluetooth takes priority automatically. And you can leave them switched on and the Bluetooth doesn't automatically connect, which is a positive feature, because you wouldn't want it connecting all the time anyway.
j
jack Lowenstein
amazing little package
beautiful in its simplicity - amazing in its power
Philip
Great value
I’ve been using this as a Bluetooth amp for Yamaha 150 W outdoor speakers on my deck for 3 years with no problems whatsoever. Sound is clear and more than enough power to annoy the neighbors. You can’t beat it for the price.
John Paxton
Wish the build quality was as good as it sounds
This is written pre approaching Fosi for a replacement because the situation shouldn’t exist. Under 2 months old and already the power switch has failed, it’s a flimsy switch but in under 40 operations failed, So going to try to return it. Everything else about the amp in terms of sound, function has been great at the price point but when it comes to adding $10 to maybe use better pots and hardware I would rather have that than to deal with that than being without music for however long this takes
