Knobs designed for subwoofer
Pre-Out Connector
  • THD: ≤ 0.03%
  • SNR: ≥ 108dB
  • Input: Bluetooth + RCA
  • Input Sensitivity: ≤ 600mV
From $104.99
Bluetooth 2.1 Ch Amp
165W ×2+350W@4Ω
≤ 0.03%
50W x2+100W
Bluetooth + RCA
≤ 0.04%
≥98dB
24V/4.5A
TPA3116 x2
Stereo Mode
XLR Input
Subwoofer Channel
Based on 80 reviews
71%
(57)
16%
(13)
5%
6%
(5)
Tearlach Bigger
Just plain works
Don’t really write reviews, so simply put, it does what it states with zero fuss. Only improvements…In my scenario I still need an AirPlay adaptor. Bottom line for me; it’s a great solution and relatively inexpensive compared to competitors.
Hugo
impedance
it is rated 2-8ohm but at 2ohm sub it will shutdown from overload, beside that everything great
B R
Clean Sound - small Footprint
Variable Tone Controls let you Contour the Sound for Mains and Sub very well
(Tested with a pair of EV Mains 15” plus Horn 8 ohm cabs and B52 18” sub cab 8 ohm also. Sounded great & clear tones. It was hot outside and amp got warm but that would be understandable at higher volumes with so large of a system being tested )
Saras Dewi
Wrong Power Supply
I just received the unit after paying customs duties and sadly it was shipped to Indonesia 🇮🇩 with a United Kingdom 🇬🇧 Power Supply. This should be an obvious quality control issue. I will have to use a travel adaptor 🥲
ISAAC CARRANZA
Shipping taking forever.
It’s been nearly 2 weeks, I have not received my shipment of the product. I’ve been checking the status and it’s been in transit for days.
