Knobs designed for subwoofer
Pre-Out Connector
  • THD: ≤ 0.03%
  • SNR: ≥ 108dB
  • Input: Bluetooth + RCA
  • Input Sensitivity: ≤ 600mV
From $104.99
Bluetooth 2.1 Ch Amp
165W ×2+350W@4Ω
≤ 0.03%
50W x2+100W
Bluetooth + RCA
≤ 0.04%
≥98dB
24V/4.5A
TPA3116 x2
Stereo Mode
XLR Input
Subwoofer Channel
Based on 81 reviews
70%
(57)
17%
(14)
5%
6%
(5)
Kenneth Clunis
Useful tool
A good quality amp that I found useful in selecting a crossover frequency for a 3-way speaker system of my own design
Tearlach Bigger
Just plain works
Don’t really write reviews, so simply put, it does what it states with zero fuss. Only improvements…In my scenario I still need an AirPlay adaptor. Bottom line for me; it’s a great solution and relatively inexpensive compared to competitors.
Hugo
impedance
it is rated 2-8ohm but at 2ohm sub it will shutdown from overload, beside that everything great
B R
Clean Sound - small Footprint
Variable Tone Controls let you Contour the Sound for Mains and Sub very well
(Tested with a pair of EV Mains 15” plus Horn 8 ohm cabs and B52 18” sub cab 8 ohm also. Sounded great & clear tones. It was hot outside and amp got warm but that would be understandable at higher volumes with so large of a system being tested )
Saras Dewi
Wrong Power Supply
I just received the unit after paying customs duties and sadly it was shipped to Indonesia 🇮🇩 with a United Kingdom 🇬🇧 Power Supply. This should be an obvious quality control issue. I will have to use a travel adaptor 🥲
