Knobs designed for subwoofer
Pre-Out Connector
  • THD: ≤ 0.03%
  • SNR: ≥ 108dB
  • Input: Bluetooth + RCA
  • Input Sensitivity: ≤ 600mV
From $109.99
Bluetooth 2.1 Ch Amp
165W ×2+350W@4Ω
≤ 0.03%
50W x2+100W
Bluetooth + RCA
≤ 0.04%
≥98dB
24V/4.5A
TPA3116 x2
Stereo Mode
XLR Input
Subwoofer Channel
Based on 84 reviews
71%
(60)
17%
(14)
5%
6%
(5)
h
hugo
great amp
very good amp considering price and physical size, doesnt distort with 48v psu, i recommend fan at 48v, only downside is led indicator should be much brighter and when it goes do standby mode in bluetooth you can hear quiet pop but its unnoticeable
י
ינון ברטוב
Great product
Amazing value for money
Market breaking!
Very satisfying with the sound and simplicity of the product
Russell Taylor
Tin Lid Was Correct
Does everything it says on the tin. Nice to have some control over the main speakers and the Bluetooth is extremely useful. I can send music from my digital player, to the amplifier, while sat in my armchair, how lazy is that? Very relaxing though. Thanks Fosi. Another great product.
Kenneth Clunis
Useful tool
A good quality amp that I found useful in selecting a crossover frequency for a 3-way speaker system of my own design
Tearlach Bigger
Just plain works
Don’t really write reviews, so simply put, it does what it states with zero fuss. Only improvements…In my scenario I still need an AirPlay adaptor. Bottom line for me; it’s a great solution and relatively inexpensive compared to competitors.
