Knobs designed for subwoofer
Pre-Out Connector
  • THD: ≤ 0.03%
  • SNR: ≥ 108dB
  • Input: Bluetooth + RCA
  • Input Sensitivity: ≤ 600mV
From $109.99
Bluetooth 2.1 Ch Amp
165W ×2+350W@4Ω
≤ 0.03%
50W x2+100W
Bluetooth + RCA
≤ 0.04%
≥98dB
24V/4.5A
TPA3116 x2
Stereo Mode
XLR Input
Subwoofer Channel
Based on 83 reviews
70%
(58)
17%
(14)
6%
(5)
6%
(5)
Tal
Misleadingly promising product saved solely by its low price
Heating issue - I have paid extra for the 48V power adapter and was disappointed to end up with a product that heats to unreasonable temperatures. I've contacted support and finally got the 32V power adapter that decreased the device's temperature. Still, the thermal design does not sufficiently dissipate the heat and will lead to shorter product life.
Sound quality - very decent, and doesn't lack power.
Knobs - no markings around them and different behavior of each knob makes it very unclear to the user. No useful information in the box.
Connectivity - the compact design makes it hard to use all the connections conveniently. I didn't use the BT function so won't comment about it.
Russell Taylor
Tin Lid Was Correct
Does everything it says on the tin. Nice to have some control over the main speakers and the Bluetooth is extremely useful. I can send music from my digital player, to the amplifier, while sat in my armchair, how lazy is that? Very relaxing though. Thanks Fosi. Another great product.
Kenneth Clunis
Useful tool
A good quality amp that I found useful in selecting a crossover frequency for a 3-way speaker system of my own design
Tearlach Bigger
Just plain works
Don’t really write reviews, so simply put, it does what it states with zero fuss. Only improvements…In my scenario I still need an AirPlay adaptor. Bottom line for me; it’s a great solution and relatively inexpensive compared to competitors.
Hugo
impedance
it is rated 2-8ohm but at 2ohm sub it will shutdown from overload, beside that everything great
