Knobs designed for subwoofer
Pre-Out Connector
  • THD: ≤ 0.03%
  • SNR: ≥ 108dB
  • Input: Bluetooth + RCA
  • Input Sensitivity: ≤ 600mV
From $109.99
Bluetooth 2.1 Ch Amp
165W ×2+350W@4Ω
≤ 0.03%
50W x2+100W
Bluetooth + RCA
≤ 0.04%
≥98dB
24V/4.5A
TPA3116 x2
Stereo Mode
XLR Input
Subwoofer Channel
