Knobs designed for subwoofer
Pre-Out Connector
  • Output Power:
  • SINAD: 89dB
  • THD: <0.006%
  • SNR: ≥106dB
  • Dynamic Range: ≥106dB
From $109.99
Bluetooth 2.1 Ch Amp
165W ×2+350W@4Ω
≤ 0.03%
50W x2+100W
Bluetooth + RCA
≤ 0.04%
≥98dB
24V/4.5A
TPA3116 x2
Stereo Mode
XLR Input
Subwoofer Channel
Based on 76 reviews
71%
(54)
17%
(13)
4%
7%
(5)
John Jesudason
Very Bad!
No power at all! Doesn’t drive my Wharfdale Towers or Bose Bookshelves. It’s just Media Hype for these mini amplifiers. Can’t compare them to Integrated Steroe Amps. Very Disappointed!
Andres
BT30D Pro. Amazing small Bluetooth amplifier
I purchased this Amplifier based on other people's reviews. I was not familiar with this brand.
I have to say, the amplifier is just amazing. The 2.1 works perfect and the separated controls for the Sub are a plus that really make a difference when adjusting the overall sound.
I have to mention that the Fosi Customer service/support was incredibly helpful throughout the process of selecting the model, the shipping and installation. My kudos to all of them. (Special thanks to Linda Chen and Carmen Liu)
I got the amplifier with the 48v power supply and a Fosi Fan to keep it cool. The combination really works well. (Great advice from customer support)
At first, the amplifier was a bit hot but not due to equipment issues.
It was my fault. Relocated everything and now is cool at all times.
It powers my passive Sub more than well enough but unfortunately doesn't have enough power to fully power my passive 200 watts JBL.
Once again, my fault. Fosi Audio clearly states that this amp is 100 +100 and JBL recommends a 200-watt amplifier. I will look for something a bit more powerful (probably from the Fosi lineup) and will move this one to the bedroom. Is too good to give it away.
The reason why I'm giving 4 stars and not five, is because this amp doesn't have a remote control and a mid-range knob.
It does a pretty good job for the mid if you play with the bass and treble knobs but still not the full potential of the JBL's mid-range 3way, 3 drivers.
In regard to overall power, once again, the FOSI team really got it right on the BT30D Pro. I placed the amplifier in the living room (30' by 13') and it fills every corner with a beautiful sound.
If you are asking yourself, why would I need more power if the sound is strong and beautiful enough for my living room?
The answer is simple: better-quality sound with more power. The JBL's have Crossover Frequency: 800, 4000Hz and 200 watts so a lower power doesn't really take full advantage of all their potential.
Not that this amplifier is not enough for a great strong sound. It is!!
Considering the amplifier itself (and not my mistakes in selecting the right amplifier for my speakers), the bass is strong with the Bass and Sub control, and the clarity of the Treble is amazing. The overall sound is incredible clear and crisp for a device so small and in this price range.
The Bluetooth is also amazing. I can walk with my phone all over my apartment and I won't get a single interruption in the sound.
The telephone volume and equalizer also help with the fine tuning of the quality of the sound.
I connected the 65" TV to the amplifier via the RCA's input connectors. A whole new world to watch movies. Love it.
The price for this amazing amp is unbelievable reasonable. I'm considering buying two more of these for my kids.
Overall, I totally recommend this unit with no doubt in my mind. Small or medium size rooms? this is the perfect 10 amplifier. Just make sure you pick the right speakers for it.
If it had a remote control I would definitively say is a 5 star plus.
I attached a video. The music is not over imposed even though the quality is so good that it looks like that. It is actually the real sound coming from the speakers and Sub powered by the BT30D Pro and captured by my phone mic. Please imagine that if that's how it sounds recorded by a phone (no professional equipment was used) how it really sounds standing here.
Disclaimer: I bought this amplifier from FOSI Audio. It was not given to me by Fosi as part of a promotion
A Sykes
Sounds great, nice subwoofer controls.
I bought this to replace a BT20a pro so that I could power a homemade passive subwoofer. It sounds great and good subwoofer controls. It does run really warm under moderate listening levels. I bought it with the 48v supply to get the most out of the amp. It would be nice if the there was an option for the sub frequency setting to actually filter out the lower frequency from the main speakers.
David James
Perfect little amp solution.
Great lille digital amp, have it setup in my workshop/study. Upgraded from the standard version for supporting bigger standmounts and a sub, not disappointed. Easy connection & good sound quality
Brent Johnson
