  • Input: 3.5mm AUX, Optical, Bluetooth. Output: 3.5mm Pre-Out, Passive Speakers+Subwoofer
  • Rated Power Output: 4.1 Channel: 30w*4+60W*1 @4Ω; 5.0 Channel: 30W*5
  • Max Power Output: 50Wx5 @4Ω
SUB/CEN Channel Mode Switch
In FLAT mode, the SUB/CEN channel outputs full-range audio signals, while in SUB mode, it outputs low-frequency signals from 20 to 300Hz.
Ambient Light Strip
Input modes are color-coded for easy use: blue for Bluetooth, orange for AUX, and red for OPT, to enhance the intuitiveness of operation.
Multi-Functional Remote
Provides functions like device power on/off, input mode switching, one-touch mute, etc., offering greater convenience.
Full-Aluminum Alloy Chassis
Constructed with a full metal casing, CNC machined, finely sandblasted for a simple yet durable and rugged design.
  • All-in-One Amp: A mini amplifier that integrates DAC and power amplification. This stereo amplifier supports up to 5 channels output, switchable between 4.1 and 5.0 channels. It features Bluetooth, AUX, and optical digital inputs, along with pre-out and support for up to 5 speaker outputs.
  • Multi-Scenario Solution: Ideal for pairing with outdoor speakers or wall-mounted speakers, perfect for setting up 2 to 5-channel audio systems in environments like patios, cafes, restaurants, bars, etc. It can also serve as a home theater or desktop HiFi system amplifier, meeting your diverse needs from indoor to outdoor settings.
  • Enhanced Immersion: Take your sim racing and home theater experience to a whole new level! By pairing with bass shakers, its sufficient power output and bass boost help significantly enhance the realism of racing simulator games. When watching movies at home, the vibration feedback can also help you experience your movies in another dimension, making every movie feel more realistic like being in a cinema.
  • Effortless Operation: Featuring a comprehensive user-friendly design with a built-in power supply, accompanied by remote control, supporting bass and treble tone adjustment, a multifunctional central knob for volume control, powering on/off and mode switching, LED mode indicator ambient light, etc. Enjoying music has never been easier.
  • Elegant and Durable: Continuing Fosi Audio's tradition of an all-aluminum alloy body design, the CNC unibody construction and fine metal sandblasting process highlight a minimalist aesthetic. The full metal body ensures durability, and you can enjoy Fosi Audio's 24-month guarantee for every unit.
  • Channel : Bluetooth 4.1 CH Amp
  • Input : Bluetooth + 3.5mm AUX + OPT
  • Output : 3.5mm Pre-Out + Speaker Out
  • SNR : ≥88dB
  • THD : ≤ 0.03%
  • Terminal Impedance : 4-8Ω
  • Rated Power Output : 30w*4+60W*1
  • MAX Power Output : 50Wx5 @4Ω
  • Work Voltage: AC 110V - 240V
  • Product Dimensions : 6.1 x 7.2 x 2 inches
  • HT4S*1
  • Power Cord*1
  • Bluetooth Antenna*1
  • 3.5mm Auxiliary Cable*1
  • Remote Control*1
  • HT4S User Manual*1
Based on 12 reviews
42%
(5)
50%
(6)
8%
Stephen Celliers
Clean sound
Clean sound.
Great for movies, Youtube, and music.
Optics still needs to be tested to see if audio quality is 'fuller'
Bluetooth signal strength is impressive. A proper 5m distance with two walls between device and amp. Not a beat missed.
Tom Griswold
Customizing the amp for 3rd party use.
I love the way the amp and looks. I think this is a great amp for home uses. I need it for 3rd party uses in vacation homes where guest can access it and not actually touch it. I needed it for 2 zones to play the same source and stay set to Bluetooth even if the power goes out comes back on. A physical switch would be great to lock it in to Bluetooth only mode. Also, it someone is connected to it and leaves the area, it will release their device and allow it for others to find it and connect to it.
I have not installed it yet at the place where it will be used, but I plan on using a IR/RF remote system to reset the amp back to Bluetooth incase it resets. This is an added cost, but it is the only way I know to work around this issue, providing the amp allows a 3 party IR system to control it.
Overall, for home use, I think this is a great amp and the remote that comes with it is a nice feature.
Manoj M Nair
Good
Power is bit low or not i donno, some audio i feel low output even at full volume
Subramanian s
Very good
Very good
R.M.
Living room ceiling speakers
👎🏻Very weak power,
👎🏻Came a week or two late,
👍🏻Perfect build quality,
👍🏻Small and stylish,
👍🏻Remote control,
👍🏻Connectivity toslink,aux,bluetooth.
