Fosi Audio K5 Pro Gaming DAC Headphone Amplifier Mini Hi-Fi Stereo for PS5/PC/MAC/Smartphone
$79.99 USD
$79.99 USD
$79.99 USD
  • Headphone DAC Amp Combo
  • 16-300 Ω Powerful Headphone Drive
  • Bass & Treble Adjustment
the upgraded version of Fosi Audio Q4
Input: USB-C/OPT/COA/3.5MM Microphone; Output: RCA/3.5mm Headphone;OPT/COASampling Rate: up to 24bit/192 kHz;
Output power: 1000mw@16Ω, 500mw@32Ω, 300mw@64Ω, 150mw@128Ω, 80mw@300Ω;
THD: <0.003%; S/N: >110db; Frequency response: 20Hz-20kHz;Recommended headphone impedance: 16-300Ω
NEW DAC Headphone Amp
RCA output can be connected to an amplifier or powered speakers on your desktop.
Exclusive Design with Independent Mic Input
Converts USB Type C/Optical/Coaxial signals to 3.5MM AUX and RCA signals with low distortion
Gaming Starts Here
Enjoy the realistic auditory experience in every detail
Stereo DAC Headphone Amplifier
K5 Pro can drive 16 Ohm to 300 Ohm headphones with low distortion and great dynamic range.
Desktop DAC and Headphone Amplifier
The knobs are high quality and turn very smoothly, they’re quite enjoyable to use.
Mini Stereo Gaming DAC
Great Value Headphone AMP/DAC with Bass/Treble Control
Gaming Starts Here
  • The upgraded version of Fosi Audio Q4 adds microphone function, K5 Pro headphone DAC amp combo, next-generation audio converter with unrivaled internals, more outstanding performance, and richer audio details. Born for Gaming. K5 Pro stereo DAC headphone amplifier is perfect for your home gaming system, equivalent to an external sound card, suitable for PS5/Computers/PC/MAC/active speakers, etc.
  • K5 Pro USB DAC converts USB Type C/Optical/Coaxial signals to 3.5MM AUX and RCA signals with low distortion and great dynamic range. Unique design: 2-in-1 USB Type C interface charging port and audio input means K5 Pro is compatible with your phones(Note: Your audio source must be connected to the USB-A/C port.). RCA output can be connected to an amplifier or powered speakers on your desktop. 3.5 MM AUX and microphone interface can drive 16 Ohm to 300 Ohm headphones.
  • K5 Pro headphone DAC adopts the Texas Instruments NE5532 op-amp chip. The circuit design implementing this DAC has been optimized for a low-noise floor and clean sound. K5 Pro has noticeably improved on overall sound quality, so you can get immersed in your music even more easily. Volume button and on button are combined into one, long press to switch on.
  • Product Specifications: K5 Pro with master volume/bass/treble control and input mode switch. USB Type C rate: up to 24 bit/96 kHz, Optical/Coaxial sampling rate: up to 24 bit/192 kHz, THD ≤0.003%, SNR ≥110dB. Output power: 1000mw@16Ω, 500mw@32Ω, 300mw@64Ω, 150mw@128Ω, 80mw@300Ω.
  • What You Get: K5 Pro DAC amp x1, 3.5MM headphone splitter x1, 2-in-1 USB Type A/C to Type C cable x1, User Manual x1, Optical Cable x1, our worry-free 24-month warranty, and friendly customer service
  • THD: <0.003%
  • SNR: ≥110dB
  • Net Weight: 0.55lb (251g)
  • Power Supply: 5V
  • Fosi Audio K5 Pro x 1
  • USB Type-C cable x 1
  • Optical cable x 1
Based on 7 reviews
71%
(5)
14%
14%
Johnny
Gave me a refund, bought another and it is amazing
I received a defective dac. It was working great for about 4 minutes before it started playing a feedback noise whenever sound was playing through the headphone jack. I tried every troubleshooting step I could think of and emailed fosi support. They had sent detailed troubleshooting steps through my email correspondence, however it became obvious to me that this unit I received was defective as it kept giving feedback noise. We were able to solve the feedback noise from playing by lowering the volume knob on the dac but it started having a consistent popping noise after just a few minutes of usage again (3-5 minutes of audio playing). This popping noise would trigger even earlier the louder the volume knob got and would show up whether i isolated the dac/amp as much as i could or tried different cables and devices. Their support team did issue a refund. I was able to buy another unit (to arrive more quickly) and it has been working just fine. The treble and bass knobs comes in very handy and sounds fantastic.
Kevin Jacob
It drives my hd 560s really wel
Was a bit skeptical about these about these because there was a lot of mixed opinions. I guess I got the updated version and it works like a charm. The build is solid and looks good. It drives my CCA Trio and HD 560s really well.
Supun Senevirathne
Disappointed
my order should have arrived one week ago. but it still has not arrived. I'm very disappointed. i paid extra money to buy in official site and this is the reward i got for that.
Erick Chan
Works well!
Works surprisingly well for an inexpensive DAC. Most of these are either super inexpensive (and seem risky); others tend to be very expensive (although they might work very well). This one audibly improved the sound quality on my small desktop computer speakers. You just need to disable any currently running equalizer or other sound adjusting apps so that this device will be recognized by Windows; then it works well every time.
w
wolf
Perfekt für Ps 5 Audio
Perfekt für die Ps5 geeignet mit guten Bass und klaren höhen und etwas mehr Lautstärke als wie in ohne den K5 Fosi.
Klare Kaufempfehlung !
