  • AccessoriesVintage Elegance: The LC30 boasts dual large VU meters, complete with adjustable brightness across five levels. It offers versatile connectivity with two inputs and two outputs, enabling four distinct configurations. Beyond its functional prowess as a switcher, it stands as exquisite decorative VU meters allowing you to enjoy the vibrant audio-visual feast.
  • Versatile Compatibility: Fully supports a wide range of amplifiers. The large enclosure design accommodates not only two Fosi Audio compact amplifiers on top but also seamlessly integrates with traditional Class A, Class B, Class AB, and tube amplifiers without issues to meet your diverse audio enjoyment needs.
  • Superior Components: Integrated with 390Ω protective load resistors, thickened copper foil circuits, premium speaker binding posts, and switching relays, the LC30 ensures virtually no impact or loss in sound quality and supports a maximum 250W power transmission per channel. This allows you to enjoy the purest high-fidelity sound.
  • Ease of Use: Offers both button and remote control operation, enabling one-tap switching between two amplifiers and two speakers. It streamlines the process of A/B comparison testing for two amplifiers or speakers, ensuring straightforward accessibility. Moreover, adjusting the backlight brightness and needle sensitivity is made effortlessly simple, enhancing the overall user experience.
  • Crafted for Audiophiles: The LC30 was specially developed to cater to our fans' requests. It embodies the Fosi Audio signature all-aluminum alloy construction for durability and reliability, complemented by a 24-month official warranty for peace of mind. This device is destined to be a lasting companion for your HiFi home audio system, ensuring enduring satisfaction.
    View more details
Model LC30
Input Up to 2 sets of amplifiers
Output Up to 2 pairs of passive speakers
Supported Amplifier Types BTL, Class A, Class AB, Class B, Class D digital amplifiers, tube amplifiers, etc.
Maximum Power Support 250W @ 4Ω (per channel)
VU Meter Size 85 x 45mm
VU Meter Brightness Adjustment 5 levels (100%, 75%, 50%, 25%, Off)
No-Load Amplifier Protection Built-in 390Ω resistor protection
Supply Voltage DC-5V
Fosi Audio LC30 x 1
User Manual x 1
Remote x 1
USB-C Power Cable x 1
Based on 37 reviews
76%
(28)
14%
(5)
11%
John Samsel
Excellent VU Meter
Exactly as described. Easy to set up and a great addition to my system.
Ben Catanzaro
Great VU meter
Perfect, worked out out of the box.
Switching two pairs of speakers with different impedance.
Like the on/off switch and meter light options and the size of the meters - visible from my siting position. Great product, well made, sturdy. Recommend.
cheers.
Tim Tussey
This is a good start in the switcher business.
I have not looked at the circuit but most things are good. I don’t understand the need high power resistors unless you are using them to protect an unconnected amp. This is not required. I have been involved in the design, manufacture, and sale of thousands of switch devices and never used resistors for this.
S.G. Pels
More for cosmetics and practicality
Although I love the nostalgic look of the LC30, it must be said that the VU meters themselves aren’t all that accurate, you constantly have to adjust them and they do not represent the actual wattage/db levels. They’re more for cosmetics than for actual accurate representation. Having said that, the LC30 is a great amp/speaker switch, and that is where it’s actual usefulness lies for me, the VU meters are more a nostalgic novelty bonus. The build quality is excellent.
Johnny Fiver
Neat looking but one major flaw
If you simply want a neat looking and limited functio switcher, this will do the trick. However, my main reason for passing on this is that when you switch from speaker A to speaker B there is no level adjustment. So, if you are comparing a 97dB speaker to an 89 dB there will be a huge volume difference when you switch. Most people perceive the one that is louder as being "better" which is just not always true. All that needs to be added is level adjustment knobs for each channel and you will have the best unit out there. This allows you to play a test tone and use a dB meter (or perhaps the ones built in) to set the volume of both speakers to the same level. Then, when you switch back and forth you will be hearing just the sound difference, not any volume difference.
